A Question About Partial Derivatives
Maor Hadad
v_{i}=\dot{x}_{i}=\dot{x}_{i}\left(q_{1},q_{2},..,q_{n},t\right)
T \equiv \frac{1}{2}\cdot{\sum}m_{i}v_{i}^{2}
\frac{\partial T}{\partial\dot{q}_{k}}={\sum}m_{i}v_{i}\frac{\partial v_{i}}{\partial\dot{q}_{k}}={\sum}m_{i}v_{i}\frac{\partial x_{i}}{\partial q_{k}}[/B]
Why is it ok to assume:
\frac{\partial v_{i}}{\partial\dot{q}_{k}} = \frac{\partial x_{i}}{\partial q_{k}}
I can say that:
\frac{\partial x_{i}}{\partial q_{k}}=\frac{\partial x_{i}}{\partial t}\frac{\partial t}{\partial q_{k}}=\frac{v_{i}}{\dot{q_{i}}} but it's not the same as written.
and the expression \frac{\partial v_{i}}{\partial\dot{q}_{k}} says to differentiate the velocity according to change of the q quardinate in time.
Maor Hadad said:
v_{i}=\dot{x}_{i}=\dot{x}_{i}\left(q_{1},q_{2},..,q_{n},t\right) T \equiv \frac{1}{2}\cdot{\sum}m_{i}v_{i}^{2} \frac{\partial T}{\partial\dot{q}_{k}}={\sum}m_{i}v_{i}\frac{\partial v_{i}}{\partial\dot{q}_{k}}={\sum}m_{i}v_{i}\frac{\partial x_{i}}{\partial q_{k}}
2. Homework Equations [/B]
Why is it ok to assume:\frac{\partial v_{i}}{\partial\dot{q}_{k}} = \frac{\partial x_{i}}{\partial q_{k}}
I can say that: \frac{\partial x_{i}}{\partial q_{k}}=\frac{\partial x_{i}}{\partial t}\frac{\partial t}{\partial q_{k}}=\frac{v_{i}}{\dot{q_{i}}} but it's not the same as written.
Maybe try:
##\displaystyle \frac{\partial x_i}{\partial t}=\frac{\partial x_i}{\partial q_k} \frac{\partial q_k}{\partial t} ##​
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
