A question on the Radion field
  • Thread starter Thread starter robousy
    Field
robousy
I'm trying to understand how a field is also a dimension.
For example, consider the following from a brane paper "...the distance between branes is a massless degree of freedom, the radion field."
Can anyone help me understand this? The field - dimensional radius relationship.
Yea, its a bit subtle, b/c how you introduce the radion field is somewhat model dependant.
So you will have a background metric in general (say RS) and you will have a parameter in front of the coordinate describing the compactified small dimensions (call it Y). So 0<y<2pi * R. Where R is really the radius of the orbifold. Convenient variable changes will lead to something like R^2 dphi^2
The radius R in the first version of RS is not determined by the dynamics so the radion field is said to be a massless degree of freedom. In other models it can be different.
The super naive way of going from the constant R to a scalar field (The Radion) is simply to promote it to r(X) (X is the other coordinates of the metric). Intuitively it sort of governs the interspacing between branes. But this naive way is not quite right, but its almost right. Anyway I leave the details in any number of arxiv preprints on the subject (I don't have one handy atm)
Thanks for the references, I'm taking a look at the GW paper now.
And thanks for the insight Haelfix.
The scalar (radion) field is not a dimension; it gives a measure of distance in a dimension. More specifically, the idea comes from general relativity in which a spacetime has no metric *a priori*, so no physical spatial and temporal measurements can be made. You can have coordinate frames, which can be arbitrarily chosen, but measurements using these frames are not physically meaningful. This is the purpose of the metric: to ascribe geometry to a (topological) space. Now, in the example of theories in 5 dimensions with a circular 5th dimension, the 5-dim metric field splits into a 4-dim metric for the 4-dim (non-compact) spacetime + a scalar "metric" for the 5th dimension + something else...The background value (vacuum expectation value in quantum field theory) of this scalar field is the size of the circle dimension *in units of the coordinate frame you choose*. (Hence the name "radion"). Another simple example is to slice 5-dim (non-compact) space with 4-dim walls; the distance between each wall corresponds to an independent scalar field as above. The idea of a scalar field corresponding to a length is more general than these examples, though.
So the radion is basically the G_55 component of the five dimensional metric G? This makes sense. It's a scalar field in the same sense that g_{\mu\nu} is a graviton.
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
Thread 'LQG Legend Writes Paper Claiming GR Explains Dark Matter Phenomena'
A new group of investigators are attempting something similar to Deur's work, which seeks to explain dark matter phenomena with general relativity corrections to Newtonian gravity is systems like galaxies. Deur's most similar publication to this one along these lines was: One thing that makes this new paper notable is that the corresponding author is Giorgio Immirzi, the person after whom the somewhat mysterious Immirzi parameter of Loop Quantum Gravity is named. I will be reviewing the...
Many of us have heard of "twistors", arguably Roger Penrose's biggest contribution to theoretical physics. Twistor space is a space which maps nonlocally onto physical space-time; in particular, lightlike structures in space-time, like null lines and light cones, become much more "local" in twistor space. For various reasons, Penrose thought that twistor space was possibly a more fundamental arena for theoretical physics than space-time, and for many years he and a hardy band of mostly...
