Ionic Bond Saturation: Binding Force & Packing
  • Thread starter hasan_researc
  • Tags
    Force
In summary, the lecturer explains that in an ionic bond, the attraction between ions is purely electrostatic and not gravitational. This is because the electrostatic force is much stronger than the gravitational force. The lack of saturation in an ionic bond allows one ion to bond with as many neighbors as possible, determined by the available space or "packing". In contrast, other forms of bonding rely on sharing a single electron between orbitals, which is a short-range force confined to the two atoms involved. The lecturer also discusses the concept of minimizing total energy in different packing patterns and the potential impact of different reference frames on energy calculations.
hasan_researc
170
My lecturer writes the following in his lecture notes:
" In an ionic bond, the force is not saturated so that one ion bonds to many near neighbours (as many as packing will allow) "
What does saturation mean in this context?
Clearly, the binding force is largely due to the electrostatic force and not gravitational, right? This is because the electrostatic force between two particles is much much stronger than the gravitational force ??
Finally, how does a lack of saturation allow one ion to bond with as many neighbours as packing will allow? And what exactly does packing mean in this context?
Any help will be greatly appreciated!
In an ionic bond, the attraction between ions is purely electrostatic, which is a long-range force. That means it is quite difficult for other ions clustering around to completely shield the charge and neutralise it. In fact, the main constraint on the number of ions clustering is just the geometrical question of actually fitting them into the space available - that's 'packing'. There are several types of packing (or stacking) patterns that might form , which are energetically more favourable (which makes them more likely) than a random pattern.
On the other hand, other forms of bonding rely on a different mechanism - like sharing a single electron between their orbitals. That's a short-range force - it's confined essentially to the two atoms involved.
Thank you! You mentioned that "it is quite difficult for other ions clustering around to completely shield the charge and neutralise it.". To what degree, nonetheless, will the surrounding ions shield the charge in an attempt to neutralise it?
"There are several types of packing (or stacking) patterns that might form , which are energetically more favourable (which makes them more likely) than a random pattern." : Why would any physical system want to minimise its total energy? Also, the total energy must surely be expressed with respect to some reference frame. What if the energy changes randomly as we shift from one reference frame to another? Surely then, the total energy if minimised w. r. t. one reference frame could possibly be greater if looked at from another reference frame !??
"On the other hand, other forms of bonding rely on a different mechanism - like sharing a single electron between their orbitals. That's a short-range force - it's confined essentially to the two atoms involved." : I thought all forms of bonding involve electrostatic forces, and electrostatic forces are long-range. So, I can't understand how the covalent bonding is due to a short range force?
Thank you for your help!
FAQ: Ionic Bond Saturation: Binding Force & Packing
1. What is an ionic bond?
An ionic bond is a type of chemical bond that forms between two atoms when one atom loses an electron to another atom. This transfer of electrons results in the formation of positive and negative ions, which are then attracted to each other and form a bond.
2. How is ionic bond saturation determined?
Ionic bond saturation is determined by the number of valence electrons in an atom. An atom is considered to be saturated when it has a full outer electron shell, which is achieved by either gaining or losing electrons to reach the nearest noble gas configuration.
3. What is the binding force in an ionic bond?
The binding force in an ionic bond is the electrostatic attraction between positively and negatively charged ions. This force is responsible for holding the ions together and forming a stable bond.
4. How does ionic bond saturation affect the strength of a bond?
The strength of an ionic bond is directly related to its saturation. An atom with a higher degree of saturation will have a stronger bond because it has a greater number of electrons available for transfer, resulting in a stronger electrostatic attraction between the ions.
5. How does packing affect ionic bond saturation?
The packing of ions in an ionic compound can affect the degree of saturation. When ions are packed closely together, it can hinder the movement of electrons and decrease the bonding capacity of the ions, resulting in a weaker bond. However, if the ions are packed in a more spaced out manner, it can allow for greater electron transfer and result in a stronger bond.
