A small doubt about electric flux
The discussion revolves around the concept of electric flux, particularly the interpretation of negative and positive values in relation to their magnitudes. Participants explore the implications of scalar quantities in electric flux and how this relates to examples from a textbook.
  • One participant expresses confusion over the idea that negative electric flux can be considered "larger" than zero flux, referencing textbook examples.
  • Another participant clarifies that while electric flux is a scalar quantity, its sign (positive or negative) indicates the direction of flow through a surface.
  • There is a question about the nature of the dot product in relation to electric flux, with a request for further elaboration on this concept.
  • One participant draws an analogy between electric flux and velocity components, suggesting that negative flux represents the same magnitude as positive flux but indicates a different direction of flow.
  • A later reply proposes that the textbook's use of "higher" or "lower" may refer to the absolute value of flux, suggesting a potential misunderstanding in terminology.
Participants do not reach a consensus on the interpretation of negative versus positive flux, and there are multiple competing views regarding the terminology and conceptual understanding of electric flux.
Some participants note the potential for confusion stemming from language use in the textbook, suggesting that the phrasing may not clearly convey the intended meaning regarding magnitudes of flux.
Joe Da Bro
Hey there...
As far as I know, electric flux is a scalar quantity which means that negative values are smaller than zero. This concept really confuses me since most of the exercises I dealt with suggest that negative flux somehow is larger than zero flux
Example 1
the uniform field is directed to the right, which surface has the lower electric flux?
is it S1 which is negative or S2/S4/S5/S6 ( that's the correct answer according to my book)?
Example 2
https://lh6.ggpht.com/f3KBE_uxMhA2zCSgcxfdIu26-n0OOGrOHNwK7lQxsSYGp__YJLIWuP7uSkZUBVLUFpwJQw=s170
Which surface has the lower electric flux?
is it S2 which is negative or S1 which is zero ( that's the correct answer according to my book) ?
So is the problem with me or with the book itself or what exactly?
Thanks in advance.
Welcome to PF;
The amount of flux passing through a surface is a scalar - not the flux itself.
The flux may be positive or negative depending on which way it flows through the surface.
Simon Bridge said:
Welcome to PF;
Isn't the flux itself a dot product? which also means it's scalar too. care to elaborate please?
Thanks for your reply...
A dot product of what with what?
Think of the flux as the amount of flow.
the electric field and the vector area
Backtrack - I think I can see a way through for you.
This is just like the component of the velocity vector in the x direction of interest is given by a dot product (##\vec v \cdot \hat i##), which will give a scalar, which may be positive or negative; but a negative speed is no slower than a positive speed. Similarly a negative flux is the same amount of flux as a positive flux, it's just headed into the volume rather than out of it ... and that is an arbitrary choice: it is just as good to define positive in and negative out.
that's what I wanted .. I am really thankful, just to make sure, negative flux>zero flux in both examples? if so then, all the doubt will vanish.. Thanks again!
I think when your book asks about "higher" or "lower" they are referring to the magnitude (absolute value) of the flux. As a native English speaker, I personally would say "larger" or "smaller", instead, because that implies magnitude. Is this an English-language textbook, or are you trying to translate from some other language? Or maybe the book was written by a non-native English speaker.
  • · Replies 16 ·
  • · Replies 20 ·
