A spherical conducting shell in an electric field field
The discussion revolves around the behavior of a spherical conducting shell placed in an external electric field, particularly focusing on charge induction on the shell's surfaces and the electric field characteristics inside the shell.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant questions whether any charge will be induced on the internal surface of the spherical conducting shell when exposed to an external electric field.
  • Another participant asserts that if the interior of the shell does not contain free charge, the shell will shield the external electric field, resulting in zero net electric field both in the metal and inside the shell.
  • A subsequent post reiterates the shielding effect and seeks clarification on the charge distribution on the inner surface of the shell and the mechanism of the shielding effect.
  • One participant explains that in a static situation, there cannot be currents in the metal, leading to a vanishing electric field within the metal. They reference Gauss' law to argue that this implies zero charge density throughout the metal, with any charge density being non-zero only at the surface, arranged to cancel the external field.
Participants express differing views on whether charge is induced on the inner surface of the shell, and the discussion remains unresolved regarding the specifics of charge distribution and the shielding mechanism.
There are assumptions regarding the absence of free charge in the interior of the shell and the static nature of the situation, which may influence the conclusions drawn about the electric field and charge distribution.
transparent
If a spherical conducting shell is kept in an electric field (say, from a point charge kept at some distance outside the shell), will any charge be induced in the internal surface of the shell? Also what will the field be like inside the shell? Thanks.
If the interior of hte sphere does not contain free charge (usually the case if we did not put it there intentionally), the outer metallic shell of the sphere will shield the external field, so that in the metal and inside the sphere there is zero net field.
Thanks. What about the charge? Will there be any charge on the inner surface of the shell? Also, how does the shielding effect work?
No. The shielding works this way: in static situation, there cannot be no currents in the metal, so electric field in the metal has to vanish. Due to Gauss' law, this also means there is zero charge density throughout the metal of the sphere. The only non-zero charge density can be at the surface and will be distributed in such a way so that it can completely cancel the external field.
  • · Replies 19 ·
  • · Replies 24 ·
9K
