Calculating Speed of Mass on a Spring
  • Thread starter Thread starter lebprince
    Spring
A horizontal spring with a stiffness of 0.8 N/m and a relaxed length of 17 cm is stretched to 25 cm with a 21-gram mass attached. When released from rest, the speed of the mass at the relaxed length is calculated using energy conservation principles, where the initial kinetic energy is zero. The relevant equations involve the conversion of potential energy stored in the spring to kinetic energy of the mass. The key to solving the problem lies in correctly identifying the initial and final positions of the spring's compression. The discussion concludes with the poster successfully finding the correct answer after clarifying the formulas and variables involved.
lebprince
A horizontal spring with stiffness 0.8 N/m has a relaxed length of 17 cm (0.17 m). A mass of 21 grams (0.021 kg) is attached and you stretch the spring to a total length of 25 cm (0.25 m). The mass is then released from rest. What is the speed of the mass at the moment when the spring returns to its relaxed length of 17 cm (0.17 m)?
Ef= Ei +W
Kf + Uf = Ki + Ui + W
so no work done W=0
Ki = 0 since released from rest
then 1/2 mvf^2 + 1/2Ksf^2 = 1\2Ksi^2
i want to find vf , i have m , i have k, i guess am having a problem with Sf and Si cause am not getting a correct answer, and am not sure if am using the right formula. Thanks
ok what is the formula when you have a spring ...late me give you hint.
Kf + Uf = Ki + Ui
you don't have to find work because there is no friction .so Uf and Ui is Zero because the hight is 0.so what left
Kf = ki
which is 1/2mv^2 = 1/2kx^2
plug the value you have k,x,and also mass
don't forget there is some trick on X.
good luck .ask if you have question
Thanks for your reply , i was able to get the right answer
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
