A system of two bodies and wall
The discussion revolves around the dynamics of two bodies, A and B, positioned against a smooth wall, with a focus on the forces acting on them. Participants debate the presence of normal and frictional forces, concluding that without upward forces, both bodies will fall due to gravity once released. The importance of free body diagrams is emphasized for understanding the forces at play, as they reveal that both bodies experience only downward gravitational forces, leading to identical acceleration. The conversation also touches on the conditions for static and kinetic friction, highlighting that relative motion is necessary for kinetic friction to act. Ultimately, the consensus is that both bodies will fall at the same rate due to the absence of upward forces.
rudransh verma
Consider the figure. The wall is smooth but the surfaces of A and B in contact are rough. Then-
1. System may remain in equilibrium
2. Both bodies must move together
3. System cannot remain in equilibrium
4. None
Newton second law.
I think there is normal force from wall and applied force will balance each other but there is no counter force against mg.Both bodies will slip and fall. I am not sure.
Did you manage to draw free body diagrams ?
[edit]
If you have to tick 1,2,3,4 (or more than one?), which is/are your best shot ?​
I have difficulties with this exercise: F is not mentioned in the text, but only appears in the picture ?​
The text uses 'remain' where you write 'be'. Also: 'must move together' and 'move together '​
Are there two versions ?​
BvU said:
The text uses 'remain' where you write 'be'. Also: 'must move together' and 'move together 'Are there two versions ?
No I wrote it in my words and yes there is F.
Then maybe it's only my personal interpretation problem: the wording 'remain in equilibrium' can (but apparently does not have to) mean that the picture is of an equilibrium (starting) situation. Never mind.
Would I be correct to assume that ##\vec{F}## is, as drawn, purely horizontal?
Would I be correct to assume that gravity is present and non-zero, even though it is not drawn?
Would I be correct to assume that "equilibrium" means that the system remains at rest if it began at rest?
If so, can you go through 1), 2) and 3) and explain why each holds or does not?
Force on B is balanced from all directions but not on A. There is no upward friction since the wall is smooth. So the system assuming is at rest in beginning cannot remain in rest and is not in equilibrium if that what we mean by equilibrium (rest).
Q1. How do you know? What are the forces on B? What balances B's weight?
(Pity you haven't done free body diagrams as suggested by @BvU.)
but not on A.
Q2. How do you know? What are the forces on A?
Q3 If A and B start at rest, do you think B (which you think is in equilibrium) remain at rest?
Q4. Is there any friction between A and B? If not, why not?
Q5 (Bonus question.) If an object is in 'equilibrium' does that mean it must be at rest?
P.S. Dd you ever find the very easy way to solve your recent problem about the falling knife using potential energy and work (2 or 3 lines of simple working)? https://www.physicsforums.com/threads/knife-dropped-on-cardboard.1011687/
Surface A and B are rough. Friction.
Wall is smooth.
After A slips B will too eventually.
I think there is no acceleration.
No!
Why not immediately? What is holding it in place?
Body A
Body A
How is body A supposed to support body B if body A is, itself, falling down?
What forces do you imagine exist between the two of them. And why?
I meant momentarily.
Friction. Given rough surface.
See Post#7 for the original quetions.
[Q1] Surface A and B are rough. Friction.
Q1. If A moves down and IF there is friction,between A and B there would be two downwards forces on B (weight and friction from A). So B would not be in equilibrium.
[Q2] Wall is smooth.
Q2. But IF A exert a frictional force on B, then B exerts an equal magnitude and opposite direction frictional force on A (Newton’s 3rd law). So B would exert a frictional force on A (even though there is no frictional force on A due to the smooth wall).
[Q3] After A slips B will too eventually.
Q3. Why ‘eventually’? What will make B start to move?
Q4. Unanswered.
[Q5] I think there is no acceleration.
Q5 You haven’t answered the question asked.
“If an object is in 'equilibrium' does that mean it must be at rest?”.
The answer is ‘yes’ or ‘no’ plus a reason.
I'll tell you the answer since it isn't directly needed to answer your Post#1 question. The answer is:
No. It would also be in equlibrium if it were moving with a constant velocity.
[P.S.] No!
P.S. How much gravitational potential energy did the knife lose in total? How much work did the resistive force do? If you can answer those two questions you can find the resistive force extremely easily.
I think you must take a step back. Drawing free body diagrams helps you to correctly think about what forces act. Until you can (correctly) draw the free body diagrams for A and B, I don't think you will be able to answer the question (IMHO).
Edited
Static friction?
Kinetic friction?
Can you reason out why neither can produce any force? Not even momentarily.
Likes Steve4Physics
Frictional forces act to oppose the relative motion that occurs, or would otherwise occur, between surfaces in contact.
For nonzero kinetic friction between two surfaces there must be some relative motion of the bodies.
For nonzero static friction between two surfaces there must be some tendency to relative motion of the bodies. I.e. in the absence of that friction there would be relative motion between them.
Likes jbriggs444
@rudransh verma:
If A and B were both perfectly smooth (zero friction between them) what would happen and why?
If A and B were both stuck together (effectively infinite friction) what would happen and why?
Both will fall down because of imbalance of forces.
I have made the diagram and I think all are balanced in the OP. So equilibrium!
Yes, they both fall. Do they fall at the same rate?
Your diagram is wrong. And the blocks are not in equilibrium.
Part of the problem is that the OP is badly worded.
Think of holding a stone stationary (in equilibrium) in your hand. You then release the stone. What force(s) act on the stone the moment after you release it? Is the stone now in equilibrium?
Think of the OP diagram as showing two blocks the moment after they were released.
Gavity is acting on the stone.
If after they were released means removal of force F then both will fall.
Will the (frictionless) blocks fall at the same rate? What is this rate?
Force F (in the OP diagram) acts horizontally and is always present. It does not get removed.
The force(s) initially suporting the blocks are not shown in the OP diagram. The OP diagram shows the blocks from the moment after the supporting force(s) have been removed.
No! Different rate since difference in mass. Acceleration due to gravity!
yeah!
What supporting forces? are you talking about normal forces and friction?
There are none. We expect that the blocks begin at rest relative to each other because we are not told otherwise. We might imagine that this was arranged by having the blocks held in place until just before we start looking at the system.
yeah
No, not different rates! Identical rates!
A heavy mass accelerates the same as a light mass (ignoring air resistance). Both have acceleration = g (= 9.8 m/s² (approx.) downwards).
Suppose blocks A and B are initially stationary and each hang on a string.
The only supporting forces (the forces preventing the blocks falling vertically downwards) are the tensions in the strings.
Now cut both strings simultaneously!
You now have the setup described in the OP. There are now no supporting forces.
Likes jbriggs444
O right!
Due to weight of B there is upward friction on A but due to weight of A there is downward friction on B. So both will come down the moment they are released at same rate g.
I have two possibilities. Which one? 1 or 2 ?
What if we treat it as a system? I think both will come down because there is no upward forces on either of them.
Well, well. After 24 posts we now have free body diagrams. The reason I asked for them is that I would like you to discover that there are no vertical forces except the two from gravity. And they cause the two blocks to fall with exactly the same acceleration. That means there is no tendency for the blocks to move wrt each other in any direction.
You have drawn friction forces, but exactly because there are no other vertical forces, the actual friction forces are zero, which makes your 1) and 2) diagrams identical. At best you have drawn the maximum friction forces, something like ##\mu F_N##.
I think there should be no friction too because there is no upward force on any of the bodies.
But there is a downward force on both bodies. What makes upward forces special in your mind?
There have to be relative motion between A and B for the friction to occur here. Wall is smooth and no upward force on B. So both will fall at same rate due to gravity after we remove supporting forces.
As I wrote, that is for kinetuc friction. For static friction there does not need to be any actual relative motion, only that there would be relative motion if the friction were not there.
  • #31
No. That's only true for kinetic friction. I will add to @haruspex's comment...
Suppose a small parachute is attached to block B. Since A and B are pressed together, there could be enough static friction to prevent them sliding relative to each other. A and B would then fall together (in the same way as if they were stuck together).
Of course If you use a sufficiently big parachute and A is very heavy, then A will fall faster than B. Sliding occurs between A and B and the friction is kinetic.
  • #32
O yeah! But there is also no static friction here because of the absence of any upward force. Both will fall as one system.
Likes BvU and Steve4Physics
  • #33
Yes indeed! If you read through the previous posts, you will see that this is the message we have been trying to convey!
Likes BvU
