What is the Speed of the Train as it Rounds a Curve?
In summary: The acceleration vectors add to some resultant a that forms the angle. The vertical component is g which means the Resultant acceleration on the lamp is given by g = ay = a*cosθ So a = g/cosθ For the x component, that means that ax = a*sinθ = g*sinθ/cosθ = g*tanθ and that is what equals the centripetal acceleration.
julz3216
A train traveling at a constant speed rounds a curve of radius 218 m. A lamp suspended from the ceiling swings out to an angle of 16.6° throughout the curve. What is the speed of the train?
mv^2/r
I drew a diagram and attempted to calculate v by setting mv^2/r = -cos16.6 mg
I don't really know how to approach this?
mv^2/r
I think the angle is with the vertical, which makes the deflection in x given as Sin16.6 not Cos 16.6.
V2/r = Sin16.6*g
V = (r*sin16.6*g)1/2
I tried and got 24.705 but that was wrong. Are there any other ways to approach the problem?
What units do they want the answer in? m/s or km/h?
24.705 m/s = 88.9 km/h
I tried both ways but neither options were correct. I think it is supposed to be in m/s and I think my answer is wrong in general, is there anything else I can do to get another answer?
Ooops. Sorry. I did a sketch and realized vertical is g and that means then that
V2 = tan16.6*g*r
Ok, I got it! Thank you so much.
It's important you understand why.
Draw the acceleration vectors. The acceleration vectors add to some resultant a that forms the angle. The vertical component is g which means the Resultant acceleration on the lamp is given by
g = ay = a*cosθ
So a = g/cosθ
1. What causes a train to slow down when rounding a curve?
When a train is rounding a curve, the centrifugal force generated by the train's movement pushes the train outward away from the curve. This force creates a lateral force, or sideways force, that must be countered by the train's wheels. This counterforce causes the train to slow down as it moves around the curve.
2. How does a train stay on the tracks when rounding a curve?
Trains stay on the tracks when rounding a curve due to the principle of coning. This means that the train's wheels are slightly tapered and angled inward, allowing them to roll smoothly along the curved track without slipping off.
3. Why do trains lean when rounding a curve?
Trains lean when rounding a curve because of the centripetal force exerted on the train. This force causes the train to tilt inwards towards the center of the curve, keeping it stable and preventing it from derailing.
4. How do engineers determine the maximum safe speed for a train to round a curve?
The maximum safe speed for a train to round a curve is determined by a combination of factors such as the train's weight, length, and wheel size, as well as the curvature of the track and the train's speed. Engineers use mathematical calculations and real-world testing to determine the maximum safe speed for a train to round a curve.
5. Can a train derail when rounding a curve?
While it is possible for a train to derail when rounding a curve, this is a rare occurrence and typically happens due to extreme circumstances such as high speeds, poor maintenance of the tracks, or unexpected obstacles on the tracks. Trains are designed with safety features and undergo regular inspections to minimize the risk of derailment when rounding curves.
