A vacuously existing function?
  • Thread starter Thread starter julypraise
    Function
julypraise
Conjecture. Suppose a\in \mathbb{R}. Suppose f is a real-valued function defined on [a,a]=\{a\}. Suppose x\in [a,a]. Then there exists a function \phi defined by {\displaystyle \phi(t)=\frac{f(t)-f(x)}{t-x}\quad(a<t<a,t\neq x)}.
(i) Before proving (or disproving this) does this conjecture make sense in the first place?
(ii) If make sense, does it truly exist?
Relevant posts are:
https://www.physicsforums.com/showthread.php?t=585386
https://www.physicsforums.com/showthread.php?t=338366
(i) If I kinda restate this conjecture, it becomes:
Conjecture. Suppose a\in \mathbb{R}. Suppose f is a real-valued function defined on [a,a]=\{a\}. Suppose x\in [a,a]. Then there exists a function {\displaystyle \phi:\{t\in \mathbb{R}: a<t<a\} \to \mathbb{R} : t \mapsto \frac{f(t)-f(x)}{t-x}}.
So it seems make sense in the ground of first order language and ZFC. Isn't it?
(ii) I think this function is simply \emptyset because the domain is empty set.
There is no number t satisfying a < t < a. Therefore, there is no t for which you have defined \phi(t). So you can say that you have vacuously created a function whose domain is the empty set. I'm not sure why it merits being called a "conjecture" or what you hope to achieve with this function.
P.S. You can equally well have said the following. Let S be any set (even the empty set) and define
\phi : \emptyset \rightarrow S
As the domain is empty, you don't need to specify any "formula" for how to "evaluate" \phi.
Yes, this function exists. It is the set of points (a, s) such that a \in \emptyset and \phi(a) = s. Since there is no a satisfying a \in \emptyset, the function is simply the empty set, as you indicated.
Maybe I do not know clearly the meaning of conjecture. Anyway what I hope to achieve with this function is to solve some problems that I posted on this post:
https://www.physicsforums.com/showthread.php?p=3808228&posted=1#post3808228
OK, to answer your question in post #3 of that thread, yes, your quotient definition defines an empty function, and that empty function exists (in the same sense in which the empty set exists). There's no logical issue that I can see with your definition.
It's also true that your statement in post #5 of that thread is vacuously true for any value L.
However, the (usual) definition of a limit isn't merely that statement. I don't have Rudin here with me, so I can't check his definition, but most authors define the limit of a function at a point x as follows:
"Let f : A \rightarrow B be a function, and let x be an accumulation point of A. Then we write \lim_{t \rightarrow x} f(t) = L if for every \epsilon > 0..."
i.e. the notion of a limit is defined only at accumulation points of the domain. Since the empty set has no accumulation points, the notion of a limit of an empty function is undefined.
Yes, what you say is exactly true and I agree with this to a full extent. But if you read my post carefully, you will see that the problem I proposed arises exactly because of what you said, that is, because the notion of limit is undefined at a point which is not a limit point, I can't use Rudin's definition to get the deriviative of a function defined at a singleton. (The problem is not of limit-definition but derivative-definition.)
Anyway as for this post, please answer to that post.
You know, all I want to get is a proper definition of derivative that I can use on a function defined on a singleton (at an isolated point). But maybe (what I'm doing) it's something time-wasting probably because general mathematicians wouldn't care about the derivative of a function at an isolated point.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
