A. What is the astronaut's centripetal acceleration during the first 20.0 s?
The discussion centers on calculating the astronaut's centripetal and tangential acceleration during the first 20 seconds of centrifuge operation. The astronaut experiences a tangential acceleration as the centrifuge speeds up from rest to a top speed of 1 rotation every 1.10 seconds, with a radius of 5.60 m. Initial calculations for tangential acceleration involve determining the change in velocity over time, leading to a linear velocity of 32 m/s. The centripetal acceleration is calculated using the formula a_c = v^2/r, resulting in a value of 182 m/s². This translates to an acceleration of approximately 18.57 g's, indicating a high level of force experienced by the astronaut.
Aim
Astronauts use a centrifuge to simulate the acceleration of a rocket launch. The centrifuge takes 20.0 s to speed up from rest to its top speed of 1 rotation every 1.10 s. The astronaut is strapped into a seat 5.60 m from the axis.
A. What is the astronaut's tangential acceleration during the first 20.0 s?
B. What is the astronaut's tangential acceleration during the first 20.0 s?
Part A.
I used a = a_r + a_t
To get a i find velocity, which is v = d/t , a = v/t
for a_r i used a_r = v^2/r
Where did I go wrong ?
Part B.
I've no idea how to do this part, any help is appreciated.
Part A + B are the same question.
I don't see how this is non uniform. He's revolving an axis with r = 5.6
Oh he's speeding up. Find the initial and final tangential velocity. If your having trouble with that find the angular acceleration, angular velocity, then multiply them by the radius. The change in velocity over the change in time will be your acceleration.
v_i = 0, v_f = \frac{1 revolution}{1.1 sec}, \Delta T = 20s
For linear velocity:
1 revolution is 2\pi r = 2\pi 5.6 = 32m
\Delta v = v_f - v_i = 35.2m/1.1s - 0 = 35.2m/1.1s = 32m/s
a = \frac{\Delta v}{\Delta T} = \frac{32m/sec}{20sec}
The calculation for angular is very similar.
Sorry for the confusion,
Here is part B.
How many g's of acceleration does the astronaut experience when the device is rotating at top speed? Each 9.80 m/s^2 of acceleration is 1 g.
Do I need to find the velocity at top speed and then divide it by 9.8 ?
How do I find the velocity at top speed. ?
I'm not really sure how to solve that problem. Youd want to find the tangential acceleration (there should be none) and divide it by 9.8. Perhaps the centripetal acceleration is what you want.
Your conditions are
v_{linear} = 5.6(2pi*.9rev/sec) = 32m/s
a_{linear} = dv/dt = 0, a_{cent} = v^2/r = 32^2/5.6 = 182m/s^2
182m/s^2 / 9.8m/s^2 = 18.57 g's Thats way too many g's.
