Does E=cB Hold for All EM Waves?
  • Thread starter Thread starter kof9595995
    Em Em waves Waves
The discussion centers on the relationship between the electric field (E) and magnetic field (B) in electromagnetic (EM) waves, specifically questioning if the relation E = cB holds for all wave solutions of Maxwell's equations. It is established that the general form of EM waves can be represented through Fourier transformation, leading to a more complex understanding of wave behavior. The equation B = (1/ω) k × E is confirmed as valid for the amplitudes of the magnetic field, maintaining the perpendicular relationship between E, B, and the wavevector k. The conversation emphasizes that while plane waves are theoretical constructs, the infinite sum of such waves can yield physical solutions. Overall, the discussion reinforces the foundational principles of electromagnetism as derived from Maxwell's equations.
kof9595995
I know for spherical or plane EM wave, there's relation E=cB, and we can prove it by the explicit expression of these two kinds of wave. But does E=cB hold for all EM waves, e.g. all possible wavelike solutions of maxwell's equation?
Hi,
electromagnetic waves have always vector character and a common relation (yield from Maxwell's equations) between the electric field \vec E(\vec r,t) and the magnetic field \vec B(\vec r,t) is
\vec B(\vec r,t) = \frac{1}{\omega} \, \vec k \times \vec E(\vec r,t)​
As you stated waves can have a more complex form! The most general form can be represented by the Fourier transformation and is a consequence of the linearity of Maxwell's equations. A general expression for the electric field in this form is
\vec E(\vec r, t) = \frac{1}{(2\pi)^{3/2}} ~ \int ~ \mathrm{d}^3k ~ \tilde{ \vec E}(\vec k) \, e^{i(\vec k \vec r - c |\vec k|t)}​
where \tilde{\vec E}(\vec k) is the amplitude of a plane wave that belongs to the wavevector \vec k. This is often called a wave packet.
So we are talking about the amplitudes of the electric field belonging to the plane wave with wavevector \vec k. But what is about the amplitudes of the magnetic field?
For the amplitudes the first equation is always true, because \tilde{\vec B}, \tilde{\vec E}, \vec k are always perpendicular. So the amplitudes of the magnetic field are
\tilde{\vec B}(\vec k) = \frac{1}{\omega} \vec k \times \tilde{\vec E}(\vec k)​
So \vec B(\vec r,t) is analogous to \vec E(\vec r,t)
\vec B(\vec r, t) = \frac{1}{(2\pi)^{3/2}} ~ \int ~ \mathrm{d}^3k ~ \tilde{\vec B}(\vec k) \, e^{i(\vec k \vec r - c |\vec k|t)} = \frac{1}{(2\pi)^{3/2}} ~ \int ~ \mathrm{d}^3k ~ \, \frac{1}{\omega} \, \vec k \times \tilde{\vec E}(\vec k) ~ e^{i(\vec k \vec r - c |\vec k|t)}​
So, the above equation is really the general solution of Maxwell's equations! Like you have seen, nothing is as easy as it seems (remember plane waves aren't physical but the infinite sum of them are as long as they vanish in infinty).
Hope i could help...
Thanks.
And where does
<br /> \vec B(\vec r,t) = \frac{1}{\omega} \, \vec k \times \vec E(\vec r,t)<br />
come from?
I assume, that we already know that the plane waves
\vec E(\vec r,t) = \vec E_0 ~ e^{i(\vec k \vec r - \omega t)}
\vec B(\vec r,t) = \vec B_0 ~ e^{i(\vec k \vec r - \omega t)}​
are solutions of Maxwell's equation. Let's calculate
\mathrm{rot} ~ \vec E(\vec r,t) = - \frac{\partial \vec B(\vec r,t)}{\partial t}
with these solutions.
\mathrm{rot} ~ \vec E(\vec r,t) yields
\mathrm{rot} ~ \vec E(\vec r,t) = \vec \nabla \times \Bigl( \vec E_0 ~ e^{i(\vec k \vec r - \omega t)} \Bigl) = i \vec k \times \vec E_0 ~ e^{i(\vec k \vec r - \omega t)}
\partial \vec B(\vec r,t) / \partial t yields
\frac{\partial \vec B(\vec r,t)}{\partial t} = - i \omega \vec B_0 ~ e^{i(\vec k \vec r - \omega t)
With these results we got the expression
\vec k \times \vec E_0 = \omega ~ \vec B_0​
Thanks a lot!
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
Hello! I would like to apply an electric field of 100 V/cm, along the z-axis (defined by an externally applied DC field), with a frequency of 100 MHz at the location of an atomic cloud (everything is inside ultra high vacuum). We can assume that the atoms are located in a volume with a diameter of 50 microns (e.g. in an optical dipole trap). However, I need to minimize any induced magnetic field along the z-axis at 100 MHz as much as possible (ideally at the nano Gauss level or below). Does...
