About expt re Newton's 2nd law
The discussion centers on an experiment designed to demonstrate Newton's second law, specifically the relationship between acceleration and resultant force on a constant mass. One participant questions the validity of using a pulley system with a hanging mass to provide the resultant force, arguing that it requires applying Newton's second law to determine tension, which contradicts the principle of proving the law itself. Others acknowledge that while calculating tension may complicate the experiment, it is still possible to apply Newton's second law to predict and verify acceleration. Ultimately, the conversation highlights different approaches to conducting the experiment while maintaining the integrity of the physics involved. The exchange leads to a clearer understanding of the experiment's execution.
grzz
hello all
Consider an experiment to prove that the acceleration in a certain direction on a given mass is directly proportional to the resultant force in that direction given that the given mass is constant. The acceleration can be measured using light gates. This resultant force can be varied by pulling on the given mass by elastic bands taking care to keep the extension of the band constant for a given resultant force.
I heard a discussion re this experiment where the resultant force was provided by hanging a mass on a pulley. i do not think this is correct Physics.
I would appreciate any reply whether I was correct in this.
Thanks.
What's your objection to it? It's not quite as direct as the example you gave. Certainly the force on the primary mass does not simply equal the weight of the hanging mass, if that's your point.
Thanks for the reply.
My objection is, IMHO, that in finding the tension on the hanging mass which is the resultant force on the given mass ( we are assuming that contact between pulley and string is smooth so that pulley does not rotate) one has to use Newton's 2nd law itself. And we were always taught that in proving some law one cannot make use of that same law.
I agree. Were I to do that 'experiment' I would not calculate the tension. Instead I'd use a force of m2g (the weight of the hanging mass) acting on the total mass of m1 + m2. Still not quite as direct as your first example, but workable.
But even if you calculate the tension, you can always think of it as applying Newton's 2nd law to predict the acceleration, then checking your prediction.
The two methods--with and without the tension calculated--are entirely equivalent, of course.
Now I have a better insight into this experiment.
Thank you.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
