Understanding Forces Between Molecules and Temperature Changes in Substances
  • Thread starter Thread starter harimakenji
    Matter
The discussion focuses on the forces between molecules in substances, highlighting that these forces are primarily electrical, particularly in the context of intermolecular interactions. When a substance is heated, its internal energy increases, which aligns with the choice of option (d) in the homework question. The conversation also touches on the behavior of mercury in capillary action, noting that smaller tubes cause mercury to rise or drop based on cohesion among its molecules. Participants express confusion over the wording of the questions and seek clarification on their answers. Overall, the thread emphasizes the importance of understanding molecular forces and energy changes in substances.
harimakenji
about "matter"
1. The forces between molecules in a substance are primarily
a. electrical
b. gravitational
c. chemical
d. mechanical
2. If a substance is heated
a. the molecules lose potential energy
b. the molecules lose kinetic energy
c. the temperature determines the quantity of internal energy
d. the internal energy of the substance is increased
3. Which one is right if the liquid is mercury
a.
b. http://wikipremed.com/image_science_archive_th/010108_th/117850_256px-CapillaryAction.svg_68.jpg (only observe first two tubes from right)
1. answer : a
reason : not sure, just read it somewhere and don't know why. Can someone please explain it why?
2. between (a) and (d), but I chose (d).
reason : if the substance is heated, it will absorbs heat energy and internal energy increases?
3. the difference between first and second picture is the height of mercury. In picture (a), the smaller the tube, the mercury will rise closer to to the surface. In picture (b), the smaller the tube (the right-most tube), the mercury will drop further from the surface.
My answer : second picture is correct because the smaller the tube, cohesion will be bigger and mercury molecules will attract each other more and cause the it to drop further.
Please help me. Thank you very much
please help me
a. electrical
b. gravitational
c. chemical
d. mechanical
It's so badly worded. All chemical bonds/intermolecular forces are electrical. It's common to say that solids are held together by electrostatic forces in the sense that electrons are shared across atoms. (Think covalent, ionic, metallic.)
Those forces aren't what is asked for though, because they say "between molecules". The intermolecular forces arise from electric dipoles rather than sharing of electrons. So someone could call them "chemical forces" if they wanted to. Just be prepared to argue either way.
OK, I think I get what you mean. Can you please help me on other questions?
Thank you very much
Thank you very much
But you already answered the other questions! Have some confidence.
I am not sure if my answer is right so I asked for confirmation. But I think my answers are correct.
Thank you very much for your help
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
