Colder Metal on Wooden Deck: Physics and Physiology Explained
  • Thread starter jack1234
In summary, the conversation discusses the difference in temperature sensation between a metal bar and wooden deck. Although the metal bar may radiate more heat, it does not necessarily mean it is colder. The temperature sensation is affected by heat conductors and insulators, as well as physiology.
jack1234
133
Question
A metal gar stand on a wooden deck feels colder than the wood around. Is the metal bar necessarily colder? Explain.
Attempts
I am not sure what does it means “necessarily colder”? The answer seems to be no, but how should I explained?
When you are feeling a sensation of cold when you touch an object, what are you feeling? Look at it another way. If you were to to put a small stick of wood and cast-iron frying pan in an oven set to 300 deg F, which one would you prefer to grab with your bare hands and why. Both are at 300 deg, so what's different about them?
Thanks, followed is my attempts:
Due to the metal bar radiate heat at a higher rate to the surrounding than the wooden deck, hence we absorb more heat from the metal bar, and therefore we feel it is hotter. However, the rate of heat radiation does not reflect the current temperature of the substance.
Is it correct?
Good explanation. It's all about heat conductors versus heat insulators.
Back to your original problem about the metal and wood on the deck. If they are both outside and at the same temperature (cooler than your skin temperature), why will the metal feel colder than the wood when you touch it? This problem is part physics and part physiology.
What does "colder" mean?
"Colder" is a comparative adjective used to describe a lower temperature than another object, person, or environment.
How is "colder" measured?
"Colder" can be measured using a thermometer or other temperature measuring device. It is usually measured in degrees Celsius or Fahrenheit.
What causes things to become colder?
Colder temperatures are caused by a decrease in thermal energy, which can be caused by factors such as heat loss, evaporation, or a change in atmospheric conditions.
What are the effects of colder temperatures on living organisms?
Colder temperatures can have a variety of effects on living organisms, including decreased metabolism, slowed growth, and even death if the temperature drops low enough.
How can we protect ourselves from the effects of colder temperatures?
To protect ourselves from the effects of colder temperatures, we can wear appropriate clothing, seek shelter, and stay physically active to generate body heat. We can also use heating devices or build fires to warm ourselves and our surroundings.
  • Earth Sciences
