About satellite launching and satellites in orbits
The discussion revolves around the mechanics of satellite launching and the dynamics of satellites in orbit. Participants explore the relationship between the Earth's rotation, the required horizontal velocity for achieving orbit, and the implications of launch angles and speeds on satellite trajectories.
  • Some participants propose that a satellite acquires horizontal velocity from the Earth's rotation, but question whether additional horizontal speed is necessary for practical reasons.
  • Others explain that rockets initially travel vertically and then curve their trajectory to achieve a tangential path, which is essential for entering orbit.
  • A participant notes that while the Earth's rotation provides some horizontal speed, achieving orbital speed is significantly higher than this initial speed.
  • Discussion includes the concept of geostationary orbits, where a satellite's speed matches the Earth's rotation, and the need for additional horizontal speed for orbits below this altitude.
  • One participant highlights the importance of launching horizontally to optimize fuel efficiency, especially in the absence of atmospheric drag.
  • There is a discussion about the relationship between launch angles and the height attained by projectiles versus satellites, with emphasis on the need for a quantitative explanation of these dynamics.
Participants express varying views on the necessity of additional horizontal speed for satellite launches, and there is no consensus on the optimal launch strategy or the implications of launch angles on orbital mechanics.
Some claims rely on specific assumptions about atmospheric conditions and the mechanics of orbital dynamics, which are not fully explored or resolved in the discussion.
PhysicsStudnt
Dear Experts,
When we launch a satellite, we launch it from Earth which is spinning, so the tangential velocity component of the point on the surface where the rocket is launched from will be acquired by it. Is that the only horizontal velocity or is the rocket accelerated at an angle upward? How is it practically done?
The rocket starts out going vertically upwards, then the engines are "steered" so as to make the flight path curve into a "horizontal" (actually tangential) one.
Thank You. I still have a little doubt regarding this. Even if i don't impart it any horizontal speed,i guess it will still have a horizontal speed resulting from the fact that it is sent from a plane that is spinning. So why do i need to impart more horizontal speed? is there any technical or practical side to it?.
Orbital speed
From wikipedia the Earth radius is 6371.0 Km it take 24h for one turn: 463m/s
depending on your altitute there is different Obital speed but it is multiple time the Earth rotation.
V=[itex]\sqrt{\frac{GM}{r}}[/itex]
So i guess it is arguably less compared to the orbital velocity.
I just find a good example geostationary orbit occur when the satellite speed equal Earth rotation it is at 36 000 km everything below that need more horizontal speed.
The geostationary orbit requires more horizontal speed too. Geostationary means same angular speed, not same tangential speed. But there is an orbit beyond the geostationary that has the same tangential speed as the surface at the equator, so it doesn't require any tangential acceleration.
If there was no atmoshpere, you'd want to launch horizontally as soon as possible to make efficient use of fuel, since the goal is to increase velocity, not climb vertically which has to oppose the force from gravity. With an atmosphere, drag presents another opposing force, and it's a compromise made to accelerate both vertically and horiztonally, reducing thrust if needed until the astmosphere is thin enough that you don't stress the launch vehicle. Most of the change in speed occurs after a launched aircraft is nearly horizontal, well into the very thin upper fringes of the atmosphere. The thrust may be completely horizontal, but the spacecraft continues to "climb" since the increase in speed results in an outwards spiraling path.
When i send a projectile up, the height attained clearly relates to the angle of projection. But quite differently, when i launch a satellite, the height it attained is independent of the angle of projection. In fact, i guess, both the horizontal and vertical components in a launch contribute to increasing the distance from the surface of the earth. But how can i explain this more quantitatively and mathematically.
Don't be thinking just about the height - you also have to consider the shape of the orbit, how elliptical it is.
  • · Replies 58 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 28 ·
