B What Determines Induced Voltage in a Transformer?
  • B
  • Thread starter Thread starter Wston
    Transformers
Induced voltage in a transformer is directly related to the number of turns in the coil, as described by Faraday's Law, which states that voltage is proportional to the number of loops of wire. A coil with more turns generates a stronger electromotive force (EMF) because it interacts more effectively with the changing magnetic field produced by the primary coil. The discussion highlights that a changing magnetic field creates an electric field, which in turn induces current in the secondary coil. The overlapping electric fields around each turn of the coil contribute to the overall strength of the induced voltage. Understanding these principles is essential for grasping the mechanics of electromagnetic induction in transformers.
Wston
As I understand in transformer when there are two sections of wire, changing magnetic field induces voltage into another wire.
Can anyone tell why induced voltage depends on how many loops of coil there are ?
Less loops of coil there are in secondary coil, less voltage will there be induced by magnetic field.
Hi
welcome to PF :smile:
have an educated guess
lets take a primary coil with a fixed number of turns, it's going to generate a magnetic field of a certain strength
now within that magnetic field a coil of 10 turns and a coil of 100 turn
in which coil will a greater EMF be generated and why ?
google Faraday's Law for some ideas
then come back and let us know what you found and how to answer the above questionDave
Hi, and this is what I have found: Generated voltage equals to -N times ΔΦ/Δt, where ΔΦ=AB ( A - area of coil, B - external magnetic field, N - number of turns).
In a coil of 100 turn there will be 10 times more voltage generated compared to coil of 10 turns, according to that formula. Why it depends on the number of turns though ?
Maybe I am formulating the wrong question because I don't really understand this at present. When a changing magnetic field is generated in one coil and there is a second coil in its vicinity - current will be induced. Now which scenario occurs for the second coil when magnetic field changes ?
1. Changing Magnetic field -> Electric field -> Current (moving electrons)
or
2. Changing Magnetic field -> Current ?
If its the 1st one, then could it be that generated electric field is in turn produced by individual electric fields around each turn of coil interfering with each other ? (like with magnetic fields around each turn in inductor that interfere and overlap to produce stronger field)
Think it through ... what does a 100 turn coil have that a 10 turn coil doesn't have ?
and with that, what is the effect of the magnetic field on the 100t coil compared to the 10t coil ?
yes, but it is a little more complex than that and you don't have to go that deep to understand the basics
simply, a changing magnetic field generates a changing electric field and so on ... this is an electromagnetic field
Dave
Thanks for responses. I think 100 turns has more conductive materiel in magnetic field. Although isn't it already covered with the A - area of coil in the formula ? In that case what brings N to the table.
Dave
I wasn't sure about this, so does it mean whenever there is a changing magnetic field, electric field is generated and that electric field creates the voltage that forces electrons to move (current), am I understanding this right ? (without going to Einstein's relativity I was wondering if I am understanding the mechanics here just in simpler magnetic and electric fields).
If this is right (changing magnetic field ->generated electric field->induced voltage and current), maybe form of the coil matters (N, turns) because of electric fields around turns somehow overlapping with each other and creating a general strengthen electric field ? I am thinking of an analogy of current running through an inductor where individual magnetic fields around each turn overlap and create a greater, general magnetic field. Otherwise I am not sure. I just don't understand why form of the coil (and even area of the coil) would contribute to the strength of the generated electric field (and hence strength of the voltage) in the secondary coil by the changing magnetic field from the primary coil.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
