Absolute Zero & Time: Does Time Stop?
The discussion revolves around the relationship between time, temperature, and black holes, particularly the concept of absolute zero. It is suggested that if an object were cooled to absolute zero, time would effectively stop for it, although achieving absolute zero is deemed impossible due to zero-point energy. Black holes are noted to have a temperature related to Hawking radiation, which is not zero kelvins, and their internal conditions are complex and not well-defined. The conversation also touches on the nature of time within black holes, with some arguing that time does not exist in the traditional sense inside their event horizons. Overall, the interplay between thermodynamics and time at extreme conditions remains a topic of debate.
neokill3r
I was thinking time is just change in matter. So theoretically if something was cooled to absolute zero would time stop for it?
I can't give you an answer. In this zone of the planet the weather is not so cool as zero kelvin. I think I will have to wait till next winter.
Well, time dilation and thermodynamics are linked in black holes, isn't it?.
But, remembering my lectures of one of Hawkins book, I think temperature of black holes is not zero kelvins. They emit radiation. Its temperature corresponds to the formula:
T=hc^3/(8*pi*k*G*M)
h=Planck constant
k=Boltzmann constant
G=Universal gravity constant
M=black hole mass
c=light velocity.
The temperature of a black hole of some solar masses is 0.000001 K.
It is said that inside a black hole there is no time rate.
Althoug I'd better think that an astrophysic could answer straightforward you than I can.
"So theoretically if something was cooled to absolute zero would time stop for it?"
What do you mean by "something"? If you cool a living creature to absolute zero, for sure time (and everything else) will stop for it!
If you are not talking about living things how would you know if "time stopped for it"? I suppose you could look at the "life spans" of elementary particles but when you are at that level, how do you stop it long enough to find out?
History channel lol
Actually I was just watching the history channel two or three days ago and saw a show on this very subject.
They have had different things at close to absolute zero (+/-0.01 deg I think was the temp range of absolute zero) and stuff started acting really weird, liquids were rolling up the walls and some solid don't remember now what it was turned to liquid. it was really interesting, might want to look up the history channel line up for the past 2 or 3 days and try to figure out the name of the show and watch it.
I posted a year ago proposing that time is the same as the transfer of energy by points of matter.
See my current post in Quantum physics on particles and spacetime. The point is that spacetime is an EFFECT of elementary particles exchanging energy. They do not exist in spacetime but give rise to it.
It is my conclusion that yes, if something is frozen to absolute zero time would stop and it would not interact with other matter. It would not only act weird, it would probably disappear. As to the question of what the object might be, it would not matter. If something is frozen to only near absolute zero, time continues and there is some interaction and deterioration, but at absolute zero there would be no change at all.
However, I believe it is impossible to freeze anything to absolute zero.
i doubt very much that black holes are near Absolute Zero.
all that gravity, on such a dence object, would make one hell of a friction reactor.
i'd say a black hole is one of the hottest things in the universe.
Yes, you're right. You are the only person that would say that. And you would have a further disagreement with Stephen Hawking too.
well pardon me for using logic.
if something is being squeesed, it will heat up. that is why suns are hot.
black holes having gravity so strong not even light can get out, would surely there for have the same effect.
You are missing a lot. If what you are saying were correct Black holes would be visible. Since this is not the case we must assume that your logic is flawed. Perhaps you need to do a bit of research into the life cycle of stars, "gravitational collapse" is a nice key word.
It should be noted that molecules still vibrate at absolute zero with what is known as zero-point energy, it is impossible to completely 'freeze' something (as indeed by thermodynamics it is impossible to reach absolute zero).
Black hols do have a property called 'temperrature' and it's simply a measure of the amont of blackbody (i.e. Hawking) radiation they emit. Gara's not too far off the mark, the accretion disk of a black hole can and often does get very, very hot (see active galactic nuclei, for the most extreme examples), due to friction, though the Hawking temperature of a black hole is dependent on it's size menaing tyat all black holes formed by stellar collapse (i.. all observed black holes)have Hawking temps below that of the CMBR (i.e. very nera absolute zero), though a primordial black hole could be very 'hot' indeed.
I think talking about temperature inside a black hole has no sense at all. You are forgetting the statiscal meaning of the temperature. Surely the particles inside black holes don`t have the behavior of classical kinetic theory than have outside it. The heat transfer inside a black hole is in particular very difficult to imagine for me. Then we cannot state of an unique temperature inside, or you think that particles inside have kinetic energy?. I'm not sure at all.
The sense of temperature here is the one shown by the radiation spectrum of the hole, non the internal temperature. Both are not the same thing. The sun shows a 5500 K spectrum of radiation, but it doesn't go with its internal temperature, that likely will be different.
As it happens string thery offers a statistical interpretation of a black holes temp. The term 'internal temp.' is non-sensical when applied to a black hole, a black holes temp. is simply a measure of the Hawking radiation it produces (just like the temp. of any perfect balckbody is a measure of it's radiation spectrum).
i just had a thought.
a black hole can't have friction because of its density, nothing has room to move.
or am i wrong on that too?
Well what do you mean? you have to be more specific than black hole, as I siad before the accretion disc of a balck hole has plenty of friction, but this lies outside the event horizon.
i mean what the singularity (sp?). if everything is broken down and made into one giant (pea sized, i hear) atom/molecule, 1 atom/molecule can't rub against its self. so that means no friction.
Time does not exist, so it cannot stop.
If you could measure the temp. inside the BH's event horizon you would probably find -1 K as "temp"...a distinct absence of EMR...as evidenced by the absence of emissions (from inside the BH's EH)
As for atoms, as I have heard, the Nucleus remains active, thermally even as low, in K, as they can get them...
The singularity is a point (i.e. it has zero volume) that cannot be well-described.
Mr. Robin Parsons, rember that there is nothing special about the event horizon orthe region inside the event horizon locally, an observer falling into a black hole would (as always) measure a temp. above 0K.
Lets see, temperature is a measure of ambient energy pressure', EMR, the inside of the event horizon of a BH has no EMR, ergo no ambient energy pressure, absence is usually measurable as such, negative value, -1 K...usually...
True; and this fact should have been enough to put the issue of 'stopping time' to rest.
Please take note StephenSwires. If it can be shown to be true that time stops only at absolute zero, and we know zero point energy prevents absolute zero, then should we not conclude zero point energy is the reason we have time? :wink:
Black holes do have a property called 'temperrature' and it's simply a measure of the amont of blackbody (i.e. Hawking) radiation they emit. ...[/B]
True again; Hawking showed that you can assign a finite 'temperature' to a BH due to the fact that it emits particles and radiation by the quantum tunneling process.
That 'temperature' is given by:
T = h(kappa)/2pi(k)(c),
where 'kappa' is the surface gravity and the others are the usual constants... Planck's, Boltzmann's, and c.
In terms of mass the 'temperature' (in *K) of a spherical BH of mass M is:
T = 10^-7[M(s)/M] *K ,
(where M(s) is a solar mass).
Quite low.
Creator
...And apparently you cannot distinguish between the inside of the event horizon and the Black Hole "Body" itself...as for radiation emitted no one has any record of any yet, so theory is just that...
