Compute Nickel Filter Thickness to Increase X-Ray Ratio
N8
If the ratio I(K\alpha)/I(K\beta) before filtering is 7.5:1 for a copper target, then compute the thickness of a nickel filter, that would increase this ratio of 500:1.
Mass Absorption Coefficients (cm^{2}/g)
Cu: \rho = 8.93 g/cm^{3}
K\alpha (0.1542nm)
\mu/\rho = 51.54
K\beta (0.1392nm)
\mu/\rho = 38.74
Ni: \rho = 8.91 g/cm^{3}
K\alpha (0.1542nm)
tex]\mu/\rho[/tex] = 48.83
K\beta (0.1392nm)
\mu / \rho = 282.8
I_{x} = I_{0} e^{-\mu x}
The answer is 20 microns.
Trying to align these equations up and solve has not yielded the correct answer. Also, the effect of filter on the mass absorption coeffient can be modified by weight fractions (\mu / \rho ) = x(\mu / \rho)_{1} + (1-x)(\mu / \rho)_{2}where x is the weight fraction of one element.
But I am not sure how to incorporate this into my calculations.
Also, unfortunately, my book Structure of Materials (Graff) does not provide any worked out problems.
Any help would be much appreciated.
nevermind I was ably to solve this with the relevant equation and calculations for the linear absorption coeffecients of Kalpha and Kbeta for Nickel under copper radiation
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
