Accelerating a car including the moment of inertia of the wheels
The discussion revolves around calculating the acceleration of a car considering the moment of inertia of its wheels. The car accelerates from rest with a given engine torque, and participants explore the relationships between torque, frictional force, and angular acceleration. Key equations include τ = Iα and a = αR, with emphasis on drawing free body diagrams for each wheel to clarify forces. Participants also discuss using energy concepts to simplify calculations, ultimately arriving at the correct expression for acceleration as a = 2τ / R(M + 6m). The conversation highlights the importance of correctly accounting for the mass of the wheels and their rotational inertia in the overall dynamics of the car.
lichenguy
A car accelerates from rest on a horizontal surface. The engine provides a
torque of τ = 200 Nm on each of the two front wheels. Each of the four
wheels on the car weigh m = 15 kg, have radius R = 0.35 m and can be
considered solid, uniform discs. The rest of the car (not the wheels) has a mass
of M = 1000 kg.
What is the acceleration of the car?
I = 1/2mR2
τ = F*R
τ = I*α
a = α*R
I can find the frictional force at one of the wheels:
Ff = τ/R
I can find the α of a wheel:
α = Ff*R/I
That means a = Ff*R2/I
Not much, but I'm not very good at this, really need help.
I don't know how to combine the body as well as the wheels. Anyone has some tips please? :D
Welcome to PF!
You will need to decide how many torques act on an individual front wheel and how many act on an individual rear wheel. In the formula τ = I*α, τ is the net torque acting on a wheel.
Likes lichenguy
TSny said:
Welcome to PF!
You will need to decide how many torques act on an individual wheel. In the formula formula τ = I*α, τ is the net torque acting on a wheel.
Thanks for the welcome :)
I'm thinking that the two back wheels get their torque from the ground while the two front wheels get the torque from the engine.
Can i do 2*Ff/4 to find the torque at every wheel?
The front wheels interact with the ground, too. Draw a free body diagram for each wheel.
No. Your free body diagrams should help.
I made one in paint only, for now.
If the frame is accelerating, then we have a fictitious force. If the frame is inertial, then we only have that one force from the front wheels that makes the car accelerate. The other forces sum up to 0, it's the gravitational force and normal forces.
In the accelerating frame, we should have zero net force so Ff-Ffictitious=0
There is no need to go to the accelerating frame of the car. You can stick with the inertial frame of the earth.
Instead of drawing a force diagram for the entire car, draw a force diagram for one of the front wheels and draw a separate force diagram for one of the rear wheels.
An alternate approach is to use energy concepts for linear and rotational motion. This approach will yield the answer more quickly, but I don't know if you've studied these concepts yet.
Likes lichenguy
I made pictures with torque and friction, do they look familiar?
I know 1/2*I*ω2 and 1/2*m*v2 for kinetic energy.
The diagram for the front wheel needs a little clarification. There would be forces on the wheel in the vertical direction that you did not show. The friction force appears to be in the correct direction if you are thinking of the car as moving to the right.
What does the arrow labeled by T represent? Arrows on a free body diagram indicate forces. Is T a force?
The diagram for the rear wheel also has the correct direction for the friction. But, again, I'm not sure what the arrow with the T represents. There are also some vertical forces acting on this wheel.
Does the friction force on one of the front wheels necessarily equal the friction force on one of the real wheels? If not, then you should use different symbols for these forces.
Likes lichenguy
lichenguy said:
I know 1/2*m*ω2 and 1/2*m*v2 for kinetic energy.
The first equation is not correct. The "m" should be replaced by what?
Otherwise, OK.
Do you know a formula for the work done by a torque?
Likes lichenguy
Otherwise, OK.
Oh, sorry, there should be an I instead of m. I edited the original post.
I fixed the wheel diagrams to be more clear now, right is positive movement.
I know power is τ*ω so work would be τ*Δθ?
OK, great. All you need now is the fundamental theorem that relates work to energy.
They look pretty good now. For the front wheel, you should indicate that there is a torque applied by the engine. This could be a curved arrow labeled by τ where the arrow is clockwise or counterclockwise (you decide).
But, if you get the energy equation set up correctly, then you will not actually need these diagrams.
Likes lichenguy
I have my last pictures ready now. Thank you for the help :)
So, the theorem says ΔK=W
It's getting late, so i will try getting the energy equation tomorrow.
Ok,sounds good.
Your diagrams look correct. But I recommend using different notations for the friction forces on the front and rear wheels.
How would you solve this problem using forces and torques?
TSny said:
Ok,sounds good.
Thanks for the help, appreciated! :smile:
I ended up with: $$a = \frac {2τ} {R(M+6m)}$$
Would it be possible to use the impulse-momentum theorem?
I'm also interested in how to do it using forces, like the above guy.
That's similar to what I get, but I do not agree with the factor of 6 in the denominator. Can you show the steps in your work?
I don't see any advantage in using this theorem. It is essentially equivalent to F = ma.
From your diagrams, set up ∑τ = Iα for the front and rear wheels. Also, set up F = ma for the car as a whole.
Likes lichenguy
I started with:
2τΔθ = 1/2Mv2 + 4*1/2mv2 + 4*1/2Iω2
then
v2 = 2τΔθ/(1/2)M+3m
Next i have to multiply the denominator by 2(xf-xi)=2RΔθ, that's what gives me the factor of 6. Did you get the factor of 3 earlier?
OK. When I solved the problem I used M for the total mass of the car including the 4 wheels. But the problem clearly states that M does not include the 4 wheels o:). As a consequence, I had a factor of 2 where you have a factor of 6.
Your answer is correct with the factor of 6. Sorry for the mistake.
Alright! Thanks.
About using torques and forces method. I thought this:
2Ffront - 2Frear = a(M + 4m)
But what would be the torques?
lichenguy said:
Alright! Thanks.
The torque equations can be used to get expressions for Ffront and Frear in terms of m and α. Use your diagrams for the wheels to help set up these equations.
Likes lichenguy
Could it be FrearR = Iα?
Is it the same at the front?
Yes. Can you identify the type of force represented by Frear?
No, the front wheel also has the torque of the engine that you need to deal with.
It's a contact force. Frictional force, i guess.
Is it:
τ - FfrontR = Iα?
Yes
Is it:
τ - FfrontR = Iα?
Yes.
TSny said:
Yes
Yes.
Cool! :partytime:
Thank you for all the help. :thumbup:
Sure. Good work!
Umm, guys, i just did this using:
2Ffront - 2Frear = a(M + 4m),
τ - FfrontR = Iα,
FrearR = Iα,
but it gave me ##a = \frac {2τ} {R(M+2m)}## instead of ##a = \frac {2τ} {R(M+6m)}##
Is something missing?
τ - FfrontR = Iα,
FrearR = Iα,
These equations look correct.
Check your work. The equations should yield ##a = \frac {2τ} {R(M+6m)}##.
I made a mistake, all good now. =]
  • #31
lichenguy said:
I started with:
then
v2 = 2τΔθ/(1/2)M+3m
Can the OP or someone else explain how that equation was simplified to get a factor of 3 in the denominator for "m"?
The original equation involves a term with rotational kinetic energy (1/2Iω2).
Was that "I" for the object's inertia converted to some kind of equivalent mass?
  • #32
Each wheel is treated as a uniform, solid cylinder for which I = (1/2)mR2. Also, for rolling without slipping, ω = v/R.
Likes NewtonianAlch
  • #33
Thank you.
I was using I = mR2, hence why it didn't come out the same.
  • #34
NewtonianAlch said:
Thank you.
OK. Glad it makes sense now.
