What Would You See on a Relativistic Journey to a Distant Star?
  • Thread starter Thread starter zeroxg
    Accelerating
zeroxg
Hi does anyone know where I can find a video that shows what one would see if one went on a relativistic journey from Earth, accelerating at 1g to a distant star?
I have some idea for example length contraction when looking perpendicular from the direction of travel, and things in front would become blue and things behind red; and the shapes would be distorted.
I have read that objects the ship has recently passed would still be visible from the front for some time, why does this happen?
Welcome to PF!
If you use Google you should be able to find a number of videos on the net showing relativistic effects, for instance [1].
[1]
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
