Is the Universe's Expansion Truly Accelerating Based on Redshift Observations?
The discussion centers on whether the universe's expansion is truly accelerating based on redshift observations. Participants clarify that observing galaxies with higher redshifts indicates they are seen as they were in the past, suggesting that the universe was expanding more slowly at earlier times. The relationship between redshift and the universe's expansion rate is explained, emphasizing that in an accelerating universe, light from distant supernovae appears fainter due to the longer time taken for light to reach us. Questions about the constancy of the speed of light are addressed, with the consensus being that current evidence supports its constancy. The conversation concludes by noting that cosmic redshift is a result of the expansion of space rather than a simple Doppler effect.
Vidar T
Can we really say that the universe is accelerating its expansion because we find that galaxies further away have more redshift? We know that we are looking back in time when we look at the stars, and when we look at the galaxies furthest away from us, we are seeing them as they were a long time ago. Accually, the older the galaxy the more redshift it has. Dont this mean that things are slowing down and that everything was moveing faster in the beginning?
Space news on Phys.org
This question is asked here with great regularity. Yes, we can be sure. I suggest a forum search for discussions.
Likes Vidar T
Thanks, i will check.
Say you observe a supernova at a redshift of z=1, i.e. a supernova that occurred when the universe was half its current size. In an accelerating universe, expansion in the past was slower than today and so, in comparison with a decelerating universe, the universe took longer to expand from half its size to its present size. Because it takes longer, light travels farther and hence supernovae appear fainter at a given redshift in an accelerating universe than in a non-accelerating universe.
Likes Vidar T
Thanx:-) I would also like to ask if we are sure that the speed of light has allways been the same, or if it is somehow affected by the expansion of the universe? I will search the treads for an answer, but i apritiate any good explination to this:-)
We are as sure as we can be at this time that the speed of light is constant. That's not to say that we are 100%, absolutely sure with no possibility that we could be wrong, only that the available evidence is overwhelmingly in favor of the speed of light being a constant.
Likes Vidar T
Well considering the numbers of redshift is going into the 8,s The galaxies would have had to be moving 8 times the speed of light.
I've been wrapping my head around this all day lol.
There's a nice formula for the relativistic doppler effect. It is not as simple as just z itself or z+1 but you can look it up.
Google "relativistic doppler" and see what you get.
I get
https://en.wikipedia.org/wiki/Relativistic_Doppler_effect#Motion_along_the_line_of_sight
So if z = 8 (e.g. the example you mentioned) then 1+z = 9
that z+1 is usually a more useful number than z itself, it is the actual ratio of wavelengths, or frequencies
And then you can solve for β which is the radial speed expressed as a fraction of the speed of light---namely β = v/c
(1+β)/(1-β) = 81
80/82
But nobody is saying that the galaxies are moving that fast thru the flat non-expanding Minkowski space of special relativity . The cosmo redshift is not a doppler effect of some relative speed at this or that time.
It is the cumulative effect of how much the distance grew while the light was traveling. A GR thing not an SR thing.
z+1 = distance now/distance then
distances grow at changing speeds throughout the whole time so there is no simple way to analyze in doppler terms based on this or that speed. Wavelengths are stretched by the same factor as distances.
I think you know that, but say it anyway in case anyone reading does not.
