Acceleration due to gravity of a rocket
When a rocket is launched with an initial upward acceleration, the acceleration due to gravity, which acts downward at 9.8 m/s², must be considered to determine the total acceleration. The confusion arises from whether to add or subtract this gravitational acceleration. The correct approach is to add the gravitational acceleration to the rocket's upward acceleration to find the net thrust needed for lift-off. This is because the thrust must not only counteract gravity but also provide additional acceleration. Understanding this relationship clarifies the calculations involved in determining the rocket's thrust.
AlphaA
If an object say a rocket is thrown up in the sky with an additional acceleration say ' x ' , then why do we add the value of acceleration due to gravity i.e 9.8 m/s^2 to the acceleration ' x' in order to find the total acceleration...
Since vector of acceleration due to gravity is directed downwards...so we consider it - 9.8 m/s^2 . So in accordance to this, if we find total acceleration then we should subtract 9.8 m/s^2 from 'x ' m/s^2 because...firstly, gravity is -9.8 m/s^2 and secondly, acceleration due to gravity will constantly decrease if the rocket or object will continue going up int he sky with that X acceleration. So why should 9.8 m/s^2 be added to X m/s^2 and not subtracted ?
If you add a negative value you're subtracting it, no?
##a+(-b)=a-b##
##a+(-b)=a-b##
But as the bookish explanation says, we add the positive value of acceleration due to gravity and not the negative one...
So here adding it means adding it only...
That's why I am confused...
Need some help and guidance
That doesn't seem right. Can you provide more context for the question? Perhaps a verbatim description of the problem as stated in your book? (a picture will do)
The example goes on like this :
A rocket with a lift-off mass 20,000 kg is blasted upwards with an initial acceleration of 5.0 m/s^2 . Find the initial thrust(force) of the blast.
Take g=9.8 m/s^2
Solution (as given in my book) :
The rocket moves up against gravity with an acceleration of 5.0 m/s^2 .
Hence the blast produces a total acceleration of =
a=9.8+ 5.0 =14.8 m/s^2
By Newton's II law, the initial thrust(force) of the blast is =
F=ma = 20,000 kg x 14.8 m/s^2 =2.96 x 10^5 N.
Therefore, answer is 2.96 x 10^5 N
Take g=9.8 m/s^2
My doubt is the underlined portion only. If the rocket moves against gravity then why should acceleration due to gravity be added to the initial acceleration?
That could be written more clearly to show what's going on.
Try this:
##a=g+t##
where a is the net acceleration (5m/s^2, positive is up), g is the gravitational acceleration (-9.8m/s^2) and t is the thrust you want to find. Here, the signs show you the directions of the vectors.
If you rearrange the above to solve for t, you get the equation in your book.
The book simply went straight for the rearranged equation.
Note that the acceleration due to gravity is not
but is deducted from the net (initial) acceleration. ##-(-9.8) = +9.8##
To get the proper acceleration, relative to free fall. That's what the engine must provide to cancel gravity and accelerate up.
Try this:
##a=g+t##
Not that the acceleration due to gravity is not
Oh...THANKYOU soooooooooooooooo much...
I got it!
I can now see it clearly...yaa...I've undersood it now...
Once again...THANKS A LOT !
It was really very sweet of you to guide me ...
Gratitude.
5 - (-9.8)=14.8
Chet
Chestermiller said:
5 - (-9.8)=14.8
Chet
Thank you so much .. Sir...
I got it !...
It was really simple and I was stuck at it like anything...
Thank you so much for helping me out.
I got it !...
It would have been much easier if you had drawn a free body diagram of the rocket, and then, based on the free body diagram, written the force balance:
F - mg = ma
Chet
Perhaps think like this...
How much thrust would the rocket have to produce so that it only just manages to lift off the ground without accelerating upwards?
Then how much more does it have to produce to accelerate upwards at "a"?
What's the total?
  • · Replies 30 ·
  • · Replies 47 ·
