Acceleration in Two Dimensions of watercraft
To determine the final velocity of a watercraft with an initial velocity of 6.4 m/s [E] and an average acceleration of 2.0 m/s² [S] over 2.5 seconds, the velocities should be separated into x (east) and y (south) components. The x component remains constant at 6.4 m/s, while the y component starts at 0 and increases due to the acceleration. The final velocity in the y direction can be calculated using the formula vfy = viy + ay * t, where viy is 0. The final velocities in both dimensions can then be combined using the Pythagorean theorem to find the resultant final velocity. This approach clarifies the necessary steps to solve the problem effectively.
chudzoik
A watercraft with an initial velocity of 6.4 m/s [E] undergoes an average acceleration of 2.0 m/s2 for 2.5 s. What is the final velocity of the watercraft?
vf = vi + a * t
a = v / t
v = v2 + (-v1)
pythagoras and cosine law?
I think I need to separate the velocities into x and y components and calculate the final velocity in both the x and y components to find the final velocity, but I don't know if that's correct. To be honest I don't really know where how to start the question.
chudzoik said:
I think I need to separate the variables into x and y components and calculate the final velocity in both the x and y components to find the final velocity, but I don't know if that's correct.
Yep, that's how you should do it. You've got the x acceleration and y acceleration, and so you can solve the equations of motion for each coordinate separately.
But I don't think I have enough known variables to do that. If I use vfx = vix + ax * t then I don't have ax and I don't have the initial velocity in the y direction either so I can't figure out the final velocity in the y direction.
Yes, you do have ax, because the question says that the acceleration is only in the south direction.
And you do know the initial velocity in the y direction, because the question says that the initial velocity is purely to the east.
So they are both 0 then? I think that clears up a lot of my confusion with this problem.
Yep. that's right
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
