MHB Find Acceleration: Car Stops from 100 m/s in 410 m Distance
  • Thread starter Thread starter mathkid3
    Acceleration
To find the acceleration of a car that stops from 100 m/s over a distance of 410 m, the correct formula to use is a = (v_f^2 - v_i^2) / (2 * Δx). The final velocity (v_f) is 0 m/s, and the initial velocity (v_i) is 100 m/s, with Δx being 410 m. Substituting these values yields an acceleration of -12.2 m/s², indicating deceleration. The discussion clarifies that negative acceleration is valid and emphasizes the importance of using the correct equation and values. Understanding these concepts is crucial for solving similar physics problems accurately.
mathkid3
Find the acceleration of a car that comes to a stop from a velocity of 100 m/s in a distance of 410 m.Answer: -24.39 The answer has been given back to me as incorrect
is this because I inputed a negative value and acceleration cannot be negative?Thanks!
Mathematics news on Phys.org
Hi mathkid3, :)
Acceleration can be negative. Think of it as deceleration. So that's not the issue.
What equation did you use to solve for "a"? I suggest using ${v_f}^2={v_i}^2+2ad$
If we assume constant acceleration $a$, then we note that:
(1) $\displaystyle \Delta v=v_f-v_i=at$
(2) $\displaystyle \Delta x=\frac{1}{2}at^2+v_it$
From (1), we may state:
$\displaystyle t=\frac{v_f-v_i}{a}$ and substituting into (2) we find:
$\displaystyle \Delta x=\frac{1}{2}a\left(\frac{v_f-v_i}{a} \right)^2+v_i\left(\frac{v_f-v_i}{a} \right)$
Multiplying through by $2a$ we obtain:
$\displaystyle 2a\Delta x=v_f^2-v_i^2$
This is equivalent to the relation cited by Jameson. And so:
$\displaystyle a=\frac{v_f^2-v_i^2}{2\Delta x}$
Now plug-n-chug! :cool:
a = (0-85) / 2deltax
what is delta x ?
I can only get to the above and/or if I ignore delta x I would get something like acceleration = -42.5 or deceleration is this casehelp Mark!
$\Delta x$ is how far the car moved during its acceleration, which is given as 410 m.
$v_f$ is the final velocity, and since the car came to a stop, this is $0\,\dfrac{\text{m}}{\text{s}}$
$v_i$ is the initial velocity which is given as $100\,\dfrac{\text{m}}{\text{s}}$
So, plug in those values (along with the units, it is important in a physics course to get used to carrying the units too) and what do you get?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
