Acceleration through a non-uniform curve
The discussion focuses on designing a roller coaster that starts at 100 meters above ground, requiring calculations of lateral and vertical g-forces acting on riders. The creator has derived a velocity function based on conservation of energy, but struggles to express acceleration in terms of position rather than time. They reference the brachistochrone problem, which illustrates the optimal path for minimizing transit time, and suggest that a similar approach could be applied to their roller coaster design. The need for assistance is urgent, as the project deadline is approaching. The conversation highlights the complexities of integrating physics concepts into roller coaster design.
xoon
So we are designing a roller coaster for a project, the roller coaster starts at 100m above ground and it has to go through all of these elements. for the whole ride, i need to find the lateral and the up/down g forces that are acting on the rider.
for the roller coaster itself, i have made a function for the roller coaster but i do not know how to get the acceleration components.
what i have so far is that v=ds/dt. but the problem is that my velocity does not depend on time, it depends on height because of conservation of energy. my velocity right now is.. v=Sqrt(2*g*(ho-h)). i do not know where to go from here, because it does not depend on time. i need acceleration in terms of position.
some other equations I've looked at are dv/ds*v=a(s) --> v*dv=a(s)*ds
i've been staring at this for about a day now and the project is due monday. please help..
Also look at Isaac Newton's brachistochrone problem and solution. See
http://mathworld.wolfram.com/BrachistochroneProblem.html
The brachistochrone curve is the minimum transit time curve from start to finish, and is a cycloid. The cycloid initially accelerates very fast, the curve dips below the finish line, and then the acceleration lessens to zero and decelerates as the finish line is approached. See Mathematica simulation in
http://curvebank.calstatela.edu/brach/brach.htm
The story goes that someone proposed the problem to Newton, and he solved it in one day, having "invented" calculus of variations to do it.
I am hoping that someone, sometime, builds a brachistochrone roller coaster.
Bob S
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
