himura137
- 12
1)Which of the following is not both a Bronsted-Lowry acid and a Bronsted-Lowry base?
a. OH-
b. HSO4-
c. SH-
d. HCO3-
e. H2PO4-
I knwo its not HCO3, H2PO4- AND HSO4-, but i cannot figure out whether OH can act as an acid and base or not, i know its produced when a base react with water, but not sure if itself can be reacted as a acid and base since if it does, OH would become O2 or H2O, not sure if that's possible.
2)
Which reaction of these potential acids and bases does not occur to any appreciable degree due to an unfavorable equilibrium?
a. NaC2H3O2 (aq) + HI
b. NaNH2 in liq. NH3 + ethanol
c. CH3Li in hexane + ethyne
d. NaOH (aq) + CH3CH2CH2CO2H
e. CH3CH2ONa in ethanol + ethene
For it to have an unfavorable equilibrium, one of the reactant would have to be a strong acid or base, since HI, NH3, NaOH are strong acid or base, they would form unfavorable equiibrium as the reaction would only go one way, i am unsure whether whether the chemicals in C and E are strong acid or bases.
3) Comparison of the acidity of strong acids in solution requires the use of a solvent less basic than water
this would be false because something that is less basic than water would make it an acid, and you can't compare strong acid with weak acid in the same solution, which mean that statement is false. Am i right?
Please help, thank you
a. OH-
b. HSO4-
c. SH-
d. HCO3-
e. H2PO4-
2)
