Acid-Base low concentration of weak acid
The discussion addresses the assumption in textbooks that water's contribution of H+ ions is negligible when the K-constant of a weak acid exceeds that of water. It raises concerns about scenarios where the concentration of the weak acid is low, potentially making water's H+ ions significant. While typically, acid concentrations are sufficient for the assumption to hold, the general case requires careful consideration. The conversation emphasizes the need for a more nuanced understanding of acid-base equilibria at low concentrations. Accurate pH calculations must account for all sources of H+ ions, including those from water.
alingy1
My textbook assumes that whenever K-constant of a weak acid is bigger than K-constant of water, the water should be a negligible source of H+ ions.
However, how do we know that the concentration of weak acid could be too low and the H+ ions from water can actually have a significant effect?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
