Understanding the Applicability of the Acoustics Wave Equation
In summary: So when considering the higher pressure waves, you would derive an acoustics wave equation in which you didn't make small amplitude waves approximations?
Radiohannah
49
Hello!
When considering the acoustics wave equation
[tex]\frac{\partial^{2}P}{\partial t^{2}} = c^{2} \nabla^{2} P[/tex]
I don't really understand why you can say that the applicability of this equation varies for different sound pressure levels. I don't see why this shouldn't hold for all pressures? Am I missing the point somewhere?
Hannah
The acoustic equation describes small linearised perturbations about the steady state of the fluid.
For large amplitudes of pressure and velocity the fluid behaviour is not linear. For example the velocity of the vibrating fluid as predicted by the acoustic equation might be greater than the speed of sound in the fluid. Or the pressure amplitude might be greater than the static pressure in the fluid, so the minimum pressure (according to the acoustic equation) would be negative. Both of those situations are physically impossible.
So when considering the higher pressure waves, you would derive an acoustics wave equation in which you didn't make small amplitude waves approximations? I get it now! Thank you :-)
Great, thanks! With that further approximation that the sound waves are adiabatic, PV^{\gamma} = constant, does that also then put limitations on the pressures that can be described by the acoustic equation?
That's right. For example you find that the wave velocity depends on the amplitude. There are also non-sinusoidal shapes of waves that can propagate.
The bottom line is "can the energy go anywhere fast enough to make a difference". For most applications of acoustics the answer is no, but obviously you could have a situation where would make a difference - for example if the temperature change was large enough that radiation heat transfer was important. Heat conduction in gases is usually very poor, and if it wasn't poor you wouldn't get adabatic behaviour.
There is usually no measurable difference between adiabatic and isothermal behaviour in liquids, because Cp/Cv is very close to 1. But what happens in liquid nitrogen at supercritical temperatures, and frequencies of the order of THz, may well be interesting if you want to make a "cloud chamber" type of detector for sub-atomic particles...
http://arxiv.org/PS_cache/cond-mat/pdf/0512/0512383v1.pdf
That's super, thank you!
Related to Understanding the Applicability of the Acoustics Wave Equation
What is the Acoustics Wave Equation?
The Acoustics Wave Equation is a mathematical formula that describes the behavior of sound waves in a medium, such as air or water. It relates the change in pressure or amplitude of a sound wave to its frequency, wavelength, and speed of propagation.
What are the variables used in the Acoustics Wave Equation?
The variables used in the Acoustics Wave Equation include pressure (P), density (ρ), velocity (v), frequency (f), wavelength (λ), and speed of sound (c). These variables are related by the equation: c = √(P/ρ).
How is the Acoustics Wave Equation used in real-world applications?
The Acoustics Wave Equation is used in a variety of real-world applications, such as designing acoustic systems for buildings, predicting sound propagation in the ocean, and analyzing the behavior of musical instruments. It is also used in medical imaging techniques, such as ultrasound, and in noise control and reduction methods.
What are the limitations of the Acoustics Wave Equation?
The Acoustics Wave Equation assumes that the medium through which sound travels is homogeneous and isotropic, meaning that it has consistent properties throughout and in all directions. In reality, this is not always the case, and the equation may not accurately predict sound behavior in complex environments.
How does the Acoustics Wave Equation relate to other wave equations?
The Acoustics Wave Equation is a specific form of the more general wave equation, which describes the propagation of all types of waves, including light and electromagnetic waves. It is also related to other specific wave equations, such as the Schrödinger equation, which describes the behavior of quantum mechanical particles.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
