Action without equal and opposite reaction
  • Thread starter Jdo300
  • Tags
    Reaction
In summary, this website is a funny conspiracy website that discusses ways to block microwave mind programming signals.
Jdo300
554
Hi All,
I just read an interesting website talking about Newtons laws and how they apply in one respect but not in another (not referring to the quantum area). I personally have no opinion one way or another but thought it would be interesting to see what you all think :-).
http://montalk.net/science/90/action-without-equal-and-opposite-reaction
- Jason O
Well, I think that the author is very wrong.
Carl
Yeah, he's wrong. Total momentum is what matters - having part of the momentum angular and part linear is not a contradiction of Newton's first.
And the device is an application of that error and doesn't work. If the writer chooses to do the math on that device, he'll find that it will not move. Better yet, he could build it and compare its motion to his prediction.
The author seems to forget that angular motion has linear motion as a part of it and vice versa. For example, look at the first diagram on the page, the one where a mass of mass M approaches a barbell system where two masses of mass M/2 are separated by a rod. You might make the argument that angular momentum is not conserved in the collision because initially, there's only linear momentum and the final product involves angular momentum. However, there actually is angular momentum involved before the collision. Picture a vector drawn from the center of mass of the system to the approaching mass M. The angle of this vector changes with time, so there is angular momentum (I can't remember the exact equation, but it involves a cross product). It should be reasonable obvious that linear momentum is conserved because when mass M hits the barbell, the barbell will not only spin, it will translate to the right. Finally, you could make the argument that energy that energy that goes into linear momentum doesn't go into angular momentum, but that ignores the fact that linear momentum and angular momentum are two different things that can't be added like translational and rotational energy.
From montalk.net:
Correct Method of Analyzing a Hybrid System: During initial conditions, the barbell was stationary and the first mass moved at a certain velocity. Thus, all energy was initially stored in the first mass...During final conditions, the first mass was stationary and the barbell moved, thus the final energy was stored entirely in the barbell.
(Note that this is for the first mass being M and the masses at the ends of the barbell each being M/2.)
This is entirely wrong! The only way for the first mass to lose all of its speed is for the masses at the barbell ends to have mass M. If they have mass M/2, then [itex]v_1'=v_1/3,\ v_2'=(4/3)v_1[/itex], and the speed of the barbell c.of.m is [itex]v_2'/2[/itex]. The fact that the mass that is hit is attached to another by a rod is irrelevant to the initial evaluation of the problem, since as is usual for these idealized cases, the interaction is assumed to be instantaneous.
Similarly, the cart that can begin moving just by internal interactions inside it, is wrong. The brick that kicks off the left end and then transfers motion to the internal wheel will bring the cart entirely to rest when it does so. Linear momentum is conserved with no qualifications.
A good homework problem is to demonstrate that the contents of the website are pure nonsense. Further, this problem is worked out in many textbooks; and, the normal way of solving the problem actually agrees with experiment. In fact, spending any more time on such nonsense is a waste of time.
That the conservation laws work for isolated systems has constantly been verified by experiment, no matter what the components of the system are. They, for example, were crucial in the establishment of the reality of neutrinos.
Beware of one-trick horses.
Regards,
Reilly Atkinson
Jdo300 said:
Hi All,
[silly website deleted]
- Jason O
So tell me, out of curiosity, how in the world did you find such a silly website?
Zz.
FredGarvin said:
I learn something new every day...
http://montalk.net/conspiracy/55/how-to-block-microwave-mind-programming-signals
That's a darned funny web site.
Man there's a much simple way to protect your brain from government control.
DIY aluminum foil hat: http://koti.mbnet.fi/roine/salaliitto/foliohattu.php
The captions are in Finnish though but a picture says more than a thousand words.
1. What is Newton's third law of motion?
Newton's third law of motion states that for every action, there is an equal and opposite reaction. This means that when an object exerts a force on another object, the second object will exert a force back on the first object that is equal in magnitude but opposite in direction.
2. What is an example of action without equal and opposite reaction?
An example of action without equal and opposite reaction would be a rocket launching into space. The rocket exerts a force on the gases in its engine, causing them to be pushed out of the back of the rocket. This creates a reaction force that propels the rocket forward, but there is no equal and opposite force acting on the rocket itself.
3. Can action without equal and opposite reaction violate Newton's third law?
No, action without equal and opposite reaction does not violate Newton's third law. This law only states that for every action, there is an equal and opposite reaction. In the case of the rocket example, the reaction force is still present, just not acting on the rocket itself.
4. How does the concept of action without equal and opposite reaction apply to collisions?
In collisions, action without equal and opposite reaction can still be observed. When two objects collide, they exert forces on each other that are equal in magnitude but opposite in direction. This is why objects involved in a collision experience a change in motion.
5. Can action without equal and opposite reaction be seen in everyday life?
Yes, action without equal and opposite reaction is present in many everyday situations. For example, when you push against a wall, the wall exerts an equal and opposite force back on you. This is also true for activities like walking, where your feet push against the ground and the ground pushes back on your feet with an equal and opposite force.
  • Other Physics Topics
9K
  • Classical Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
