Active Antennas: How Do They Work?
  • Thread starter Jdo300
  • Tags
    Antennas
In summary: A very small current pulse is applied to the piezoelectric crystal and produces a large voltage swing across the crystal. This wideband output can be used to drive a lowpass filter, amplifier, or other circuitry. In summary, an active antenna can receive a stronger signal from a transmitting source by transmitting a wave of the same frequency such that the EM waves of the active antenna cancel out the incoming waves.
Jdo300
554
Hello All,
I have a question related to the understanding of how an active antenna works. From my *extremely limited* knowledge of the subject, I hear that an active antenna is able to receive a stronger signal from a transmitting source by transmitting a wave of the same frequency such that the EM waves of the active antenna cancel out the incoming waves? And that this action actually increases the effective apature (assuming I'm using the right word there) of the antenna.
If this is true, I want to know if one could create the same effect using a couple of coils in the following situation: For this example, I consider the case where I have one coil with an RF signal in it, and a second coil with a DC current flowing through it. What I would like to know is if the coil with the RF signal in it, can actualy absorb some of the magntic field energy from the DC coil as its magnetic field periodically cancels and un-cancels the DC coil's magnetic field (assuming that the field strengths are matched to allow this cancelation to happen.
I know this sounds like a weird question to ask but this is related to a thought experiment that I am working on. Any comments and/or criticisms welcome.
Thanks,
Jason O
An active antenna is just a short antenna with an amplifier which acts as an moderately successful impedance matching device and therefore broadens the bandwidth of the antenna when used with a length of coax which might be many wavelengths long. The output of the amplier is roughly matched to the impedance of the coax (50 or 75 ohms) so long lengths of coax could be used. The input will be HI-z and there is no attemp to match to the short antenna. Provided the coax is not too lossy it is as if you are using a short telescopic on the set itself but you are able to have the antenna further away from sources of electrical noise. They are a poor substitute for a proper sized and impedance matched antenna. Apart from impedance matching, amplifiers serve no useful purpose unless they can improve the noise figure of a a receiver. A very short antenna (in tems of wavelength) will have a small aperture.
I don't follow the bit about generating a local signal. There would be no point. You would 'jam' the signal you are trying to receive.
As far as I know a static magnetic field has no effect at all on RF. The proximity of a coil could de-tune an RF circuit but it wouldn't need any DC flowing in it. If there is a feromagnetic core involved that is another matter and DC can alter its properties esp if it pushed toward saturation but it is the feromagnetic material changing its effective permeablility and not the magnetic field acting directly on the RF in any way.
YIG (Yttrium,Iron and Garnet) Oscillators produce a wideband swept output by using the later process.
Hello Jason,
Thank you for your question about active antennas and how they work. Your understanding of the basic principle behind active antennas is correct. An active antenna is able to receive a stronger signal by transmitting a wave of the same frequency in the opposite direction, causing the incoming waves to cancel out and increasing the effective aperture of the antenna. This is known as interference cancellation and is a key feature of active antennas.
In regards to your question about using coils to create the same effect, it is possible in theory but not practical in reality. Coils do have the ability to absorb and transmit electromagnetic energy, but the efficiency of this process is very low. Additionally, the strength and frequency of the magnetic fields would need to be precisely matched in order for the interference cancellation to occur, which is difficult to achieve in practice.
Overall, active antennas are a much more efficient and effective way to enhance signal strength compared to using coils. I hope this helps clarify your understanding of active antennas and their capabilities. Thank you for your interest in this topic and for seeking out further knowledge on the subject. Keep exploring and questioning, that's what science is all about!
Best,
1. How do active antennas differ from traditional antennas?
Active antennas have an integrated amplifier that boosts the received signal, while traditional antennas rely on passive components to receive and transmit signals.
2. What is the purpose of using an active antenna?
The purpose of using an active antenna is to increase the signal strength and improve the overall performance of the antenna. This is especially useful in situations where there is a weak signal or interference present.
3. How does an active antenna amplify the signal?
An active antenna uses a small amount of power from a power source to amplify the signal. This is done through the use of an integrated amplifier that boosts the signal before it is transmitted or received.
4. Can active antennas be used for both receiving and transmitting signals?
Yes, active antennas can be used for both receiving and transmitting signals. However, they are more commonly used for receiving signals due to their ability to boost weak signals.
5. Are there any disadvantages to using active antennas?
One potential disadvantage of using active antennas is that they require a power source to operate, which may not be available in some situations. Additionally, they are generally more expensive than traditional antennas.
  • Electrical Engineering
