Adding Auxillery input to a car stereo
  • Thread starter Thread starter bassplayer142
    Car Input
The discussion centers on adding an auxiliary input to a Pioneer KDC-217 car stereo, as the user currently relies on a cumbersome FM transmitter that suffers from interference. They explored soldering a 1/8 inch jack to a chip but struggled to identify the correct components. A suggestion was made to use an FM modulator, which connects to the antenna jack and provides stereo jacks for audio equipment without transmitting wirelessly. Users also noted that adapters for car stereos are available, highlighting a shift from DIY solutions to commercially manufactured options. Overall, the conversation emphasizes practical alternatives for enhancing car audio systems.
bassplayer142
I have a pioneer kdc-217 stereo for my car. Currently I use an fm transmitter and it works fine but it is just a hassle to get out and I get some interference. I found a link online on how to add a aux input by basically soldering a 1/8 inch jack to a chip that has a right line and left line input. I just got done stripping my whole unit apart and I searched online about each individual chip and I couldn't find jack (pun intended). As I put it back together I saw the fm antenna line input and I was thinking that there might be a way to have the singnal come in through there. Is there a way to take a stereo signal and convert it to the signal that fm takes and then convert it back to audio? This is the link I used.
http://blog.makezine.com/archive/2007/08/how_to_adding_auxiliary_i.html
No, there's no way to put a line level input through an antenna input.
- Warren
Try searching google for "FM Modulator".
Basically a FM transmitter that plugs into the Antenna jack on the car radio and also has stereo jacks for your audio equipment.
You can probably buy one any place that sells car audio.
So it is like a fm transmitter only it doesn't transmit the signal wirelessly? Thanks for your help
Depending on the car, people might make adapters. I bought myself a tape deck ($250!)so I could solder a headphones jack into it and then a few months later hobbyists started manufacturing adapters that plug into the tape deck plug. http://www.sylfex.com/products/AuxMod/
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
