Adding Inertia Tensors to 3D Shapes: Parallel Axis Theorem Explained
  • Thread starter Thread starter daniel_i_l
    Inertia Tensors
To combine inertia tensors of different 3D shapes into a composite shape, first determine the new center of mass. The parallel axis theorem (PAT) is then applied to find the new inertia tensors for each shape along an axis through this center. If the original inertia tensors are oriented differently, a similarity transformation using a rotation matrix can be employed to align them. After aligning the tensors to the same coordinate system, the new tensors can be calculated around the new center of mass using the PAT. This process ensures accurate integration of the inertia properties of the composite shape.
daniel_i_l
Lets say that I know the inertia tensors for a few different 3D shapes and I want to connect them together into one big composite shape. From what I understand, I first have to find the new center of mass, then using the parallel axis theorem find the new inertia tensors for each body along an axis going through the center, and then just add them up. My question in, what if the new inertia tensors around the center are around axes (plurel of axis?) that aren't pointing in the same direction. Is there a way to rotate the axis of an inertia tensor? Should I make a rotation matrix from each one of the bodies space to the new composite's space and then apply those to the inertia tensors before using the PAT? Can someone give me some details about the PAT in 3D?
Thanks.
Yes, you can rotate the inertia tensor by what's called a "similarity transformation". If R is a rotation matrix and I is the inertia matrix, then I transforms as
I' = RIR^T
Thanks - then after I rotate all the tensors into the same coordinate system I can calculate new tensors around the new center of mass using the parallel axis theorem? How is it done in 3D?
Thanks.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
