Addition of AC current and compound angle theory
The discussion focuses on solving for the output current I from two alternating currents I1 and I2 at a circuit node. The currents are defined as I1=5sin(50t + π/3) and I2=6cos(50t). Participants suggest using trigonometric identities to express I1 in a more manageable form, ultimately leading to a combination of sine and cosine terms. The final step involves adding the two currents and grouping like terms to express the result in the form Rsin(50t + α). This approach aids in simplifying the calculation of the resultant current I.
tommoturbo
two alternating currents I1 and I2 flow into a circuit node,the output current I is given by adding I1 and I 2.
find I and t, when I1 and I2 are as follows
I1=5sin(50t +Pi/3)
I2=6cos50t
i1=sin(a+b)=sina.sinb+cosa.cosb
i1=sin50t x cos 60 + sin60 x cos60t x by 1/2 gives
i1=2.5sin50t + 4.33 x cos50t
Hi guys help required on above question please not sure where this progresses
thanks
So you have I_1=\frac{1}{2}sin50t+\frac{\sqrt{3}}{2}cos50t and I_2=6cos50t
So just add them now, and group the like terms.
You will have something like Asin50t+Bcos50t to put in the form Rsin(50t+α)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
