shobin said:
If you have a person lying on their back on a bed and you turn them 90 degrees so that they now face you (side lying), how do you calculate the force (effort) required to complete that task if the person weighs 250kg ?
The second part of the question is how would you calculate the additional force (effort) required to repeat the same task up an inclined plane of 6.5 degrees.
Again, in a real life situation the main factor will be friction, in one form or another, and I wouldn't know how to estimate the friction.
I will now say some things about lifting in general, I'm aware they will not be of practical value to you.
An elevator, such as the ones in high rise buildings, uses a counterweight. The counterweight is somewhat heavier than the empty elevator cabin, to get a good match when the cabin has the usual passenger load.
Imagine a situation where there is an exact match, and all of the mechanical parts operate without friction. Then a minute upward force upon the elevator cabin would suffice to make it go up.
Of course, a minute force would only impart minute velocity to the cabin. In actual elevators the force that the elevator motors exert is not so much for
lifting the elevator cabin, but for
accelerating the cabin/counterweight assembly.
If
lifting a patient is the only requirement then the force that you need is pretty much equal to weight of the patient. Additional required force to set into motion is very small compared to that.
Same story for an inclined plane. If friction is zero, then you need to exert force just to prevent sliding down. Just a smidgeon of extra force would make the weight slide up.
All this brings me back to my first remark. The biggest problem is friction, in one form or another. That factor raises the required force significantly beyond the weight of the patient itself, but I wouldn't know by how much.
Cleonis
