How can a permeable piston be adiabatic?
A permeable piston can function as an adiabatic barrier by allowing substances to pass through while preventing heat transfer. This concept is illustrated using microporous materials that permit the superfluid component of liquid helium to flow, while blocking heat conduction. In applications like Stirling engines, the term 'displacer' is used to describe a similar mechanism, emphasizing the distinction from traditional pistons. The idealization of such systems highlights their unique thermal properties and potential applications in thermodynamic processes.
  • Understanding of thermodynamics and adiabatic processes
  • Familiarity with microporous materials and their properties
  • Knowledge of superfluid helium and its phases
  • Basic principles of Stirling engines and their components
  • Research the thermal properties of microporous materials
  • Explore the mechanics of superfluid helium and its applications
  • Study the design and function of Stirling engines
  • Investigate the concept of adiabatic processes in thermodynamic systems
Students and professionals in physics, engineers working with thermodynamic systems, and anyone interested in advanced materials science and energy conversion technologies.
arpon
How can a permeable piston be adiabatic? If substances can go in and out of the cylinder and the substances have heat energy, heat can be exchanged through a permeable piston.
I came across this term in the book, but cannot understand.
Science news on Phys.org
How can a permeable piston even be a piston?
You could use an ice cube as a piston which is permeable for water at 0 deg. , but impermeable for heat. Better even, use some porous material which strongly absorbs the substance it shall be permeable for. The substance will loose its thermal energy when first binding to the material, and then diffuse against the temperature gradiet. Microporous substances are permeable for the superfluid component of liquid Helium which has S=0, but not the non-superfluid phase, which has S>0, so they can act as nearly ideal permeable adiabatic pistons for helium.
It's an idealization. Substances can flow through the pores, but the material comprising the piston does not conduct heat. This would be the same deal as an array of insulated capillaries in parallel.
A Stirling engine involves the use of a permeable 'piston' although the term 'displacer' is used to distinguish it from the type of 'piston' you have in mind.
  • · Replies 22 ·
  • · Replies 60 ·
10K
