Adiabatic heat exchanger problem
The discussion centers on solving an adiabatic heat exchanger problem involving propane gas and superheated steam. Propane enters at 40 degrees C and 250 kPa, exiting at 240 degrees C, while steam enters at 300 degrees C and 5.0 bar, exiting as a saturated liquid. Key equations for heat transfer include Q = m * Cp * ΔT and the use of steam tables to find specific enthalpy values. The discussion emphasizes the importance of heat balances and the Joules-Thompson effect in determining mass flow rates and energy transfer rates.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with steam tables for superheated steam
  • Knowledge of heat transfer equations, specifically Q = m * Cp * ΔT
  • Basic concepts of specific enthalpy and energy balance
  • Study the use of steam tables for calculating enthalpy changes in steam
  • Learn about the Joules-Thompson effect and its implications in heat exchangers
  • Explore advanced heat exchanger design principles and calculations
  • Investigate the application of energy balance equations in thermodynamic systems
Students and professionals in chemical engineering, mechanical engineering, and thermodynamics, particularly those working with heat exchangers and energy transfer systems.
marialo
Adiabatic heat exchanger problem... Please Help!
I have this proplem as a homework assignment and I'm a bit stuck as houw to set it up. Here it is:
Propane gas enters a continuous adiabatic heat exchanger at 40 degrees C and 250 kPa and exits at 240 degrees C. Superheated steam at 300 degrees C and 5.0 bar enters the exchanger flowing countercurrent,y to the propane and exits as a saturated liquid at the same pressure.
I know how to draw the process flowchart, but the problem also asks to include in the labeling the mass of the steam fed (kg). I have no idea how to figure this out. Is it in some table, or chart?
Please Help, 'cause i am stumped!
-Thanks in advance...
Couple of questions for you: Do you own a copy of the si steam tables? Are you familiar with heat balances?
Ok, i will try and point you in the right direction .
Q= Of the steam = Q of the water
Thus Q=McpDT m= mass of water/steam Kg Cp=Specific heat Dt= (Outlet Temp - Inlet)
So call steam 1 and Water 2
M1*cP*DT1=M2*cp*DT2
OR we can say that Q=m*Hf-Hg and take the data from the steam tables for steam as we know the conditions in and out! once we know Q ofcourse...lol ( H is Empalthy)
Good luck , hope this is some help...half asleep so probs wrote crap! lol :smile:
i didn't mean water i meant propane...lol
The problem seems to relate to the Joules-Thompson effect...
"adiabatic heat exchanger" implies the heat is transferred from the hot fluid to the cold fluid. The change in energy of the hot fluid = change in energy of the cold fluid, or rather rate of energy transfer from the hot fluid = rate of energy transfer to the cold fluid.
\dot{m_h}\,c_p_h\,\Delta{T_h} = \dot{m_c}\,c_p_c\,\Delta{T_c} where h and c are hot and cold, \dot{m} is mass flow rate, cp is specific heat and \Delta{T} is the change in temperature. Or instead of c_p\,\DeltaT, one could use the change in specific enthalphy directly, which one can find in a thermodynamic table as a funtion of temperature and pressure for the given fluid.
Thats what i said...lol, but in laymen terms! :P
16K
