Adjacency Matrix Proof for Triangles in a Graph | A^3[i,i] and A^3[i,j]
In summary, the conversation discusses finding an interpretation for the entries of the adjacency matrix A^3 for a graph G=(V,E). It is shown that A^3[i,i] equals twice the number of triangles containing vertex i, and that A^3[i,j] represents the total number of ways to get from vertex i to j by traversing exactly 3 edges. The conversation also touches on the definition of matrix multiplication and the importance of considering the graph as a simple graph.
pupeye11
100
Let A be the adjacency matrix for the graph G=(V,E)
(a) Show that A^3[i,i] equals twice the number of triangles containing vertex i. (A triangle is a cycle of length 3
(b) Find an interpretation for A^3[i,j] when i does not equal j similar to the above. Prove that your interpretation is correct.
I have no clue how to even start this proof...
I'm just guessing, but an interpretation of the entries of [tex]A^2[/tex] was probably discussed before the going right to [tex]A^3.[/tex]
If you haven't really thought about [tex]A^2,[/tex] start there - it should shed some light. From there, it's not too hard to interpret [tex]A^n[/tex] for any [tex]n\in\mathbb{N}.[/tex]
Just to back up tmccullough, "I have no clue how to even start this proof..." is a pretty poor start. You must know something. What's the definition of the adjacency matrix A? What's A[i,j]?
Well the adjacency matrix is how many edges between the two vertices so A[i,j] would be 1
Doesn't A[i,j] depend on the graph? How can it always be 1?
I was assuming I was working with a simple graph only.
Ok, now I've got to look up graph theory terms. Even if it's a simple graph some vertices may not be connected. You don't need to assume it's simple to do the problem. But, yes, A[i,j] is the number of ways to get from i to j by traversing a single edge. Now what's A^2 in terms of A using index notation?
I am not sure what index notation is but are you trying to get at the fact that each entry in the matrix will then be 2^n-1 if we are looking at A^n?
No, you shouldn't assume the matrix is full of 1's. And it's not even 2^(n-1) unless the matrix is 2x2. The graph may not be that simple. The question is "what is the definition of matrix multiplication". How would you write A^2[i,j] in terms of the components of A (A[i,j]). That's what I mean by index notation. Then interpret that in terms of ways to get from i to j by traversing edges.
A^2[i,j] = A[i,j]*A[i,j]. Wouldn't this double the number of ways to get from i to j?
That is so bogus. That's not even matrix multiplication, it's more like an inner product. And even that wouldn't double things, it would square them. Look up matrix multiplication. A^2[i,j]=A[i,k]*A[k,j] where k is summed over all vertices. Now interpret that in terms of graph traversal.
I am really not getting this, the matrix multiplication makes sense but I don't get how to interpret it.
A[i,k] is the number of ways to get from i to k by tranversing a single edge. A[k,j] is the number of ways to get from k to j by tranversing a single edge. That means the number of ways to get from i to j via k is A[i,k]*A[k,j]. If you sum over all possible k then what might the interpretation of A^2[i,j] be? You've really got to think here. Please help me.
A^2 would be the total number of ways to get from i to j wouldn't it?
You meant to say A^2[i,j] would be the number of ways to get from i to j by traversing exactly two edges, I sincerely hope you meant to say. What might A^3[i,j] mean?
so A^3[i,j] would be the total number of ways to get from i to j transversing exactly 3 edges.
Right! Now might need to think about what 'triangle' means and you may indeed need to make the assumption that it's a simple graph, but I think you've got the notion of what A^n means in terms of adjacency.
alright, thanks for your help
What is an adjacency matrix?
An adjacency matrix is a way to represent a graph using a matrix, where the rows and columns represent the vertices of the graph and the values in the matrix represent the edges between the vertices.
What is a triangle in a graph?
A triangle in a graph is a set of three vertices that are connected to each other, forming a closed loop. In other words, there is an edge connecting each vertex to the other two vertices in the triangle.
What is the A^3[i,i] entry in an adjacency matrix?
The A^3[i,i] entry in an adjacency matrix represents the number of paths of length 3 that start and end at the same vertex (i.e. form a triangle) in the graph.
What is the A^3[i,j] entry in an adjacency matrix?
The A^3[i,j] entry in an adjacency matrix represents the number of paths of length 3 that start at vertex i and end at vertex j in the graph.
What is the proof for counting triangles using the adjacency matrix?
The proof for counting triangles using the adjacency matrix involves using the A^3 matrix and the concept of matrix multiplication to count the number of paths of length 3 in the graph. By multiplying the adjacency matrix with itself three times (A^3), we can count the number of paths of length 3 in the graph. Then, by looking at the diagonal entries (A^3[i,i]), we can count the number of triangles in the graph. This is because a triangle is formed when there is a path of length 3 that starts and ends at the same vertex. Similarly, by looking at the non-diagonal entries (A^3[i,j]), we can count the number of paths of length 3 that start at one vertex and end at another, which also corresponds to the number of triangles in the graph.
10K
