ADXL103 Calculation: Get Equation for Tilt Angle into MPU
  • Thread starter Thread starter fredfmah
    Calculations
2 replies · 4K views
fredfmah
Dear experts,
I'm trying to get an equation for tilt angle into a MPU. This is no problem if you can find the equation.
The ADXL103 data sheet is indeed mysterious in that it is about a chip that measures acceleration. and yet gives no formula for the relation between input signal and the output signal. i.e. Input g and output delta mV
I can see that when the chip is flat on the Earth's surface the output is zero , referenced to half of the supply voltage .
This is the information, the useful starting information:
PAGE3
So the DC output is 2.500 V at 0g
The next part of the specification gives SENSITIVITY "typical" as 1000mV/g
PAGES 6 to 8
Great load of graphs on statistical information which shows sources of error. Great, but this is later when the beast is functioning.
PAGE9
The theory of operation, but still no equation o/p = function(i/p)
PAGE10
All good basic theory on filtering and responses, fine if we know the o/p we are filtering.
Self test mentions that 750mg change in output produces a delta of 750mV, (typical I suppose )
PAGE11
There is a slight whiff of an equation. Just looking at the x-axis response.
"When the accelerometer is perpendicular to gravity, its output changes
nearly 17.5 mg per degree of tilt. At 45°, its output changes at
only 12.2 mg per degree, and resolution declines. "
Going back to PAGE3
'SENSITIVITY "typical" as 1000mV/g'
Taking a mean for my small range of 0º to 15º ; (17.5+12.2)/2 =15mg per degree
So if for example my tilt is 5º then the acceleration, Ax = 75mg
Wait a minute, this is putting the cart before the horse, because
I need to calculate Ax and then I can get the degrees from...
PITCH = ASIN(Ax/1 g)
If anyone can see the relation between tilt_angle and the DC output of this chip, I would be most grateful.
Other wise I'll just have to put it on a wooden table. Tweak the orientation for exactly 2.5000V
Then carefully change the angle with respect to the table in 3 steps of 5º Measure the change in DC output
and interpolate to get the 1degree steps from 0 to 15º
Cheers
Fred
You posted the info you seem to be asking for from page 3. :confused:
So if you turn the chip upside down you should get a reading of 0.5v.
Dear Notime , I hadn't thought of that!
Seriously,
The equation for output V I think I can deduce would have the form
V = k2 *2500 + k1 *500*sinA for positive angles ;
V = k2 *2500 - k1 * 500*sinA for negative angles,
But I also note the ADXL202 is 1999, betteer to use current offering 2003, and it also looks simpler, the ADXL103
Thanks anyway,
Bye
Fred
