Affordable Red Laser Beam: Tips and Recommendations for Straight Light
  • Thread starter Thread starter MythioS
    Laser Lighting
Affordable options for obtaining a straight red laser beam are limited due to the technology constraints that prevent red lasers from visibly showing their beams in air. Unlike green lasers, which can be seen under certain conditions, red lasers require mist or fog to make the beam visible. While red laser pointers are still available and likely cheaper than before, they typically only display a dot at the end of the beam. For projects needing visible beams, using a fog machine can enhance visibility. Alternatives to traditional lasers that produce straight lines are also suggested, but specifics on those options remain unclear.
MythioS
Hope this is an apropriate thread to be asking this.. but I am curious if anyone knows a cheap way to get a straight red laser beam?
I found this green laser pen on the net and it has a fluid light from source to point but they say the red ones simply don't have the technology or something...
the smaller the laser generator or what not the better, which is why i ended up searching the pen ones.
Thanks
Just a few years ago all laser pointers were red. I would be surprised if you can't get them anymore. If anything, they should be cheaper.
Njorl
Its a good thing your looking for a straight red laser beam , those curved ones aren't cheep.
ive been seeing pen lights in red but they only show the dot at the end of the beam. I am looking for something that will show the beam itself.
Air does not effectively scatter red light, so no red laser will "show its beam" in air. You'd need to put some mist or dust or fog in the way to scatter the beam and make it visible.
Green laser light, on the other hand, is scattered by air -- though only slightly -- so you can see the beam. However, in an enclosure about the size of a room, there's not enough scattering to see the beam of a green laser either. You need about a kilometer of air and a dark night to be able to see a green laser's beam. They work great for pointing out stars to people, for example.
If this is for a science project or something on a table-top, the best way to make a laser's beam visible is simply to use one of those party-fog machines.
- Warren
Well it doesn't necessarily have to be an official laser. of there were a way to produce the same effect? I am not sure of a light that would emit such a straight line but perhaps someone else does
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
