RSmith
- 4
Hi Guys,
First time posting, sorry if this isn't the right place to post this kind of question. A personal project involving air pressure and propulsion has lead me to a question I hope somebody may know the answer to.
Imagine hypothetically you have a turbine that has paddles with a surface area of one square inch. It's held in an enclosed casing which has an inlet tube and an outlet tube - so if you blow through the inlet tube, the turbine spins and the air is explelled out of the outlet tube. A bit like a Turbocharger in a car. If you were then to blow air through the inlet tube at a pressure of 1000psi does that mean that the turbine would spin (friction on parts etc. excluded) with 1000 lbs of torque?
I figured this would be the case seeing as the paddles were 1 square inch and obviously psi is lbs per square inch.
Many thanks,
Richard
Many thanks,
Richard
