Air temperature and relative humidity
In sauna rooms, the air temperature can exceed 90° C (194° F) with low relative humidity around 10%, allowing for prolonged exposure without severe harm. The key difference lies in the heat transfer properties of air versus water; water conducts heat much more efficiently, leading to rapid burns. Additionally, the body's ability to cool itself through sweating in a sauna mitigates the risk of overheating. In contrast, immersion in hot water prevents effective cooling and increases the risk of burns. Thus, the environment in a sauna is fundamentally different from that of hot water, enabling safer exposure at the same temperature.
salma17
In sauna rooms, people spend time in conditions of air temperature over 90° C (194° F) with a relative humidity near 10%. However, if you stick your arm into liquid water that is at a temperature of 90° C (194° F), you will be severely burned in less than one minute. Give two reasons why people are able to spend time in a sauna, but are severely burned in water at the same temperature.
I have no idea why this is! Help?
Which has more heat? A sauna with a relative humidity of 10% or a bucket of water, both at the same temperature, 90 C?
You can cool yourself in a sauna by sweating. If you were wearing a coat in a sauna you would probably over heat and die.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
