Air velocity inside a pipe (natural convection)
The discussion centers around determining the air velocity inside a pipe due to natural convection. Participants explore various equations and factors influencing air movement, including temperature differences, pressure gradients, and system design. The scope includes theoretical considerations and practical implications related to convection in confined spaces.
  • Salus seeks an equation to calculate air velocity in a pipe influenced solely by natural convection, expressing difficulty in finding relevant literature.
  • Chadi B Ghaith provides an equation for air velocity based on flow rate but is challenged by Salus regarding the unknown flow rate in the context of natural convection.
  • Participants question the system's design, including whether the pipe is cooled or adiabatic, and the implications of temperature differences on air movement.
  • Concerns are raised about the accuracy of the provided diagram for convection, emphasizing the need for a downward airflow path to maintain continuity.
  • Salus provides additional details about the system, including dimensions, heater specifications, and temperature differences, but acknowledges a lack of physics background.
  • Some participants express skepticism about significant convection occurring, suggesting that only minor transient air movements may be observed during the heating process.
  • There is a discussion about the importance of heat sources and the potential for convection to cease without them, indicating a need for more detailed system descriptions.
  • Salus mentions that data collected during the transient period shows minimal temperature change, raising questions about the effectiveness of convection in the described setup.
Participants do not reach a consensus on the effectiveness of natural convection in the described system, with some expressing doubts about significant air movement while others believe convection is occurring. Multiple competing views regarding the system's design and the factors influencing air velocity remain unresolved.
Participants note limitations in the provided information, including missing assumptions about the system's design and the need for clarity on the heat source and airflow paths. The discussion reflects uncertainty regarding the conditions necessary for effective natural convection.
SalusVF
Hi guys,
I'm doing some research in papers and literature to solve this problem but I've not found anything useful. I want to know the air velocity inside a pipe by the only effect of natural convection. I've attached a picture of the system right here:
I hope you can help me to find the equation that let me know the velocity in this system.
Thanks in advance,
Salus
This equation will help you to solve this:
V= Qa/60Pi(d/2)^2
Where, d : Pipe Inner Diameter (m)
Qa : Air Flow Rate (Actual) (m³/min)
v : Air Velocity (m/s)
SalusVF said:
Hi guys,
Thanks in advance,
Salus
What do you think you have omitted from this description?
V= Qa/60Pi(d/2)^2
Thank you Chadi B Ghaith but there is a problem with your equation, I need to know the vertical speed of the air generated by the natural convection. Applying your equation in my problem Qa is also an unknown variable.
Well, the internal diameter is not shown, but I only need the expression that allows me to know the flow rate or the vertical speed due to convection. ¿Could you help me with this?
Is the tube cooled, or is it adiabatic? What causes the temperature to be colder at the top than at the bottom? Is the pressure at the top the same as at the bottom? Don't you think that knowing the answers to these questions would help to give us an idea what we are dealing with here?
The diagram isn't even correct for convection unless there is another tube or downward airflow path we aren't being shown. It violates continuity. So we need more details about the system.
Also, the source of the heat is more important than you may think. The temperature difference in the air drives the convection, but without heat sources/sinks the convection stops before it fully develops.
So please describe the system in a lot more detail.
Well, first of all thanks for your interest and your help, and secondly I'm sorry for the missing information but I'm not physicist. Let's take a look to the things that you've mentioned:
  • Diameter: 81 mm
  • Pipe type: PVC pipe 3 mm thick
  • Pipe length: 30 cm
  • Heater: 36 W resistance set at the bottom
  • Pressure: I think there should be a gradient of pressure due to the difference in temperature, that is the reason why the air flows up, isn't it? But I don't know the exact pressure. The top of the pipe is covered then the whole system is confined inside the pipe.
  • Temperature difference: 21ºC Between T1 and T2, where T1 > T2
I thing that the system could be simplified as an adiabatic system because this process last 45s aprox. Thus, the conduction loss through the PVC probably won't need to be taken into account.
Is anything else missing?
Thanks for all!
Salus
Thanks for your suggestions, I have given more details in the Chestermiller answer. I hope you it could help.
  • Diameter: 81 mm
Thanks for all!
Salus
Is the pipe open or closed? If open, what is the temperature outside?
[Edit: misread] if the pipe is closed, what is cooling the top? The diagram can't be correct; air has to flow down somewhere. Convection is circular.
Thank you! Here I post another block diagram that is probably closer to the reality.
I hope it would be clarifying!
PD: I agree with you regarding the speed profile. I think it would be like I have drawn in the center of the cylinder and oposite in both sides. In 3D i could imaging the vectorial field like an elongated toroid. The center air moves up and the external part down.
From your description so far I'm not convinced that anything much is going to happen at all other than the contained air will get a bit warmer and it's pressure may rise a little .
What is your reason for wanting information on this - are you working on a specific project that you can tell us about ?
I'm working in a project but I cannot give you more information about that. I'm sure that something happened because I've registered this convection. The thing is that I want to justify what is happening using maths, but at the moment I've had no success.
Thank you for the comment.
In the problem as described all that I would expect to observe would be some transient air movements as the system warmed up . It may be that during the very short duration of your experiment these transients had not died away .
Really though unless you can tell us more about the design and use of this system we are just guessing what might be going on .
Well, that is totally true. The data is collected during the transient period. I've been checking the data and I've seen that in 45s, beeing the lower temperature 48ºC, the higher has only increased 0.3ºC (24.2ºC -> 24.5ºC) . Is this information helpful?
What is the warm up time of the heater ?
Nidium, I've been using the post you shared like this but I'm not sure about how to proceed:
That is my system:
I've supposed that the air is using the half pipe diameter to go up and the other half to go down, then I have these equations:$$\rho_{bottom} = \frac{353}{273 + T} \rightarrow \rho_{bottom} = \frac{353}{273 + 48} = 1.1 \frac{kg}{m^3}$$
$$\rho_{top} = \frac{353}{273 + T} \rightarrow \rho_{top} = \frac{353}{273 + 21} = 1.201 \frac{kg}{m^3}$$
$$v=\sqrt{\frac{(2g(\rho_{top}-\rho_{bottom})h)}{\frac{\lambda h\rho_{bottom}}{dh+\sum \varepsilon \rho_{bottom}}}}\rightarrow v=\sqrt{\frac{(2*9.81(1.201-1.1)0.3)}{\frac{\lambda *0.3*1.1}{0.04+1.1}}}=?$$
There is still missing how to calculate##\lambda## for the Air friction coefficient.
EDIT: I thought I've used your link but not... I've used the equations of this one: http://www.engineeringtoolbox.com/natural-draught-ventilation-d_122.html
I couldn't imagine how this information could help you to know how to calculate the final speed. Anyway, it lasts like 20' to be in a steady state, but the thing is that this hot air is suddenly applied to the system, there is a valve that puts in contact this hot air with the cold one. I suppose, this could be more useful. ;-)
Thanks Nidum!
Your description of this problem keeps changing .
It's not. I'm only adding more information. At this moment I don't know what else could be missing.
This is a rather complicated problem (especially with the ends blocked off), and I think you are trying to get too complicated with your modeling too fast. In my judgment, you need to start with simpler calculations, such as, what would the temperature distribution be if the natural convection did not occur? Even though the pipe is made of PVC (which doesn't conduct much), it still has a lot of thermal inertia relative to the air, and, on the time scale of your experiment, the pipe temperature might stay pretty cold. This would result in cooler air temperatures near the pipe wall, which would contribute to the downward flow near the walls.
I would start out by solving the transient heat conduction equation for the system, assuming convection were not occurring. This would give you a crude picture of the driving force for the circulating flow. I would also get an estimate of the temperature profile through the walls at steady state if all the heat were going through the walls (and the conductivity of the air was not a limiting factor).
The three most important things in doing modelling, especially for complicated systems like this are:
1. Start simple
2. Start simple
3. Start simple
1. Start simple
2. Start simple
3. Start simple
Chestermiller, you're right! I will try to face this problem step by step. Let's see how far I go.
Thanks a million!
  • · Replies 18 ·
