Solving a Physics Problem: Struggling with Algebra
  • Thread starter Thread starter GreenPrint
    Algebra Physics
The discussion revolves around solving a physics problem that involves algebraic manipulation of an equation. The original equation is transformed by substituting constants with letters for simplicity, leading to a new equation format. To eliminate fractions, the participants suggest multiplying by the common factor, resulting in a quadratic equation. The next steps involve expanding the equation, rearranging it to standard form, and applying the quadratic formula to find the solution for X. This method streamlines the problem-solving process and clarifies the algebraic steps needed to arrive at the answer.
GreenPrint
Ok this was a physics problem...
I'm having a hard time with the algebra part
solve for X
7.35E22/(3.84403E8 - X)^2 = 5.98E24/X^2
i have got down to this and I think it is right but it might be wrong
0 = (7.35E22 X^2)/5.98E24 - X^2 + 2(3.84403E8)X - (3.84403E8)^2
Rather than dealing with all those long and annoying numbers, let's assign letters to stand for them, and we can substitute back after all the algebra is done.
Let:
A=7.35x10^{22}
B=3.84403x10^8
C=5.98x10^{24}
So now we have \frac{A}{(B-X)^2}=\frac{C}{X^2}
You want to get rid of the fractions, so you need to multiply by the higher common factor, which is X^2(B-X)^2
Then you'll get AX^2=C(B-X)^2
Now you need to expand, move everything to one side and let the equation = 0 and collect like terms. You should get it in the form mx^2+nx+p=0 where m, n and p are all some constant, and x is the variable that you're trying to solve.
Now you can apply the quadratic formula.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
