Proving Algebraic Equivalencies and Distributive Property in a Ring
  • Thread starter Thread starter acm
    Algebra
The discussion addresses two mathematical proofs related to algebraic equivalencies and properties in a ring. The first proof demonstrates that the expressions a/b + c/d and an/(bn) + c/d are equivalent by applying the distributive property, confirming that both sides simplify to the same result. The second proof establishes that for any element m in a ring R, the product m.0 equals zero, using the distributive property to show that m.0 can be expressed as mn - mn. Both proofs are validated, with additional insights provided on the nature of the variables involved. The conversation emphasizes the importance of clarity in definitions and the application of algebraic properties.
acm
Two unrelated questions that I need checked:
i) Show that a/b + c/d and an/(bn) + c/d , n is an element of I are equivalent. All denominators are assumed to be nonzero.
ii) Prove that, in a ring R, m.0 = 0 for each m in R.
i) an/(bn) + c/d = {and + (bn)c}/(bn)d = {and + (b)nc}/(b)nd (I is distributive), Hence, a/(b) + c/d = LHS. RHS = a/b + c/d. Hence LHS ~ RHS #.
ii) m.0 = m(n - n) where n is in R
Thus m.0 = mn -mn (R is distributive)
Hence m.0 = 0
Okay, n is an integer but what are a,b,c,d? Are they integers or are they members of some general ring? Isn't it obvious that an/(bn) is equivalent to a/b?
Okay, that's a bit more complicated but works.
Hence m.0 = 0
Yes, that's fine. Another proof is mn= m(n+ 0)= mn+ m(0) and then cancel.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
