Algebra, rearranging equations
  • Thread starter Thread starter jamesd2008
    Algebra
In the discussion, a user seeks clarification on why they cannot cancel 'b' in the equation a=square root of b/b+1, while they can in square root of bc/bd. The response emphasizes that cancellation is only valid when 'b' is a factor of both the numerator and denominator, which is not the case in the first expression. The ambiguity of the original equation is highlighted, with multiple interpretations provided. The conversation also touches on the importance of understanding mathematical properties and clear communication in problem-solving. Overall, clarity in mathematical expressions is crucial for accurate manipulation and understanding.
jamesd2008
Hi hope someone can help explain this for me.
If i have the equation of a=square root of b/b+1 why do can i not cancel the b's? If the equation was square root of bc/bd i can cancel the b's right?
Thanks
James
Mathematics news on Phys.org
You can cancel the b's only when they are factors of both the numerator and denominator. b is not a factor of the expression b + 1. Put some numbers in and see how it works. If b = 3, then your expression is 3/(3 + 1) = 3/4. If you (mistakenly) canceled b, you would get 1/(1 + 1) = 1/2, which is, of course, incorrect.
In your second example, b is a factor of both numerator and denominator, so you can cancel to get c/d.
Ok Mark thanks for your reply.
James
Thanks
James
When someone presents a question like this, the trouble is ignoring of the properties of numbers which the person is expected to learn and use.
What is the justification for either canceling the b's of not canceling the b's?
To follow up symbolipoint's post:
OP's expression, "a=square root of b/b+1" is extremely ambiguous:
Which interpretation to choose:
1. a=\sqrt{\frac{b}{b}+1} "a=square root of ((b/b)+1)"
2. a=\sqrt{\frac{b}{b+1} "a=square root of (b/(b+1))"
3. a=\frac{\sqrt{b}}{b}+1 "a=((square root of b)/b)+1)"
4. a=\frac{\sqrt{b}}{b+1} "a=(square root of b)/(b+1)"
5. a=\sqrt{\frac{b}{b}}+1 "a=(square root of (b/b))+1"
Thanks for the reply's it was statement 2 that I was considering in the problem.
Hi you seem to know LaTeX.
I know this forum supports LaTeX and it's nice, but i want learn LaTeX, so what is your best advice, i.e. what LaTeX programs are good for writing Lab-reports?
another question I've got is, do you write the code for every expression or do you use the forum help with inserting code from menu?
Which one would you recommend?
thanks
But, do you understand how unclear your question was?
