Allowable energies for a Particle in a box
Nick.
Hi,
I am wondering about additional solutions to the particle in a box problem. In the one dimension the wave functions allowed all make sense with nodes pinned to an infinite potential barrier at either end and then divided into node increments related to the length of the box. However, in 2 or more dimensions there seam to be other solutions which I can't find a discussion or clarity on.
For example;
In a 2d equal box we could now also have wave paths at angles to the box faces. So there would be one path at 45deg to the faces with a wavelength different to those running perpendicular - but I don't see this solution discussed? There are also similar paths at 45deg where we get say a half wavelength reflected into a full wavelength (or more) - now we could assemble a wide variety of different allowable wavelengths.
Extend this principle to 3d and we would get numerous solutions.
What am I missing?
Putting the origin in one corner of the 2D box, one can write the eigenfunction to be ##\psi_{mn}(x,y) = A \sin (n k_x x) \sin(mk_y y)##. Writing each of the sine term in the complex exponential form, you will get
$$\psi_{mn}(x,y) = B \left( e^{i(n k_x x+mk_y y)} -e^{i(n k_x x-mk_y y)} - e^{i(-n k_x x+mk_y y)} + e^{i(-n k_x x-mk_y y)} \right)$$.
In other words, the solution of 2D infinite box is a superposition of 2D plane waves. You also see, for a given ##m## and ##n##, there can be no reflected wave whose wavelength differs from the incoming one.
Ok let's look at the wave number kx=nπ/L for the typical wave in 1D and this 2D solution. But we could also produce a standing wave, bound at nodes, at 45deg located in the middle of the side L equal to n45π/√L/22+L/22 - where n45is a not a whole number increment from n. This solution requires the wave to follow a path - rather than fill the space - but why is that not a suitable solution ?
By following a path, do you mean similar to a vibrating rope instead of a vibrating surface?
Yes - that's a great analogy. Why aren't the rope solutions suitable as well as the surface?
Wavefunction with a functional form like a vibrating rope might exist as an arbitrary wavefunction in a 2D infinite box, but it cannot serve as one of the eigenfunctions of the Hamiltonian because it doesn't satisfy the eigenvalue equation ##H\psi_{mn} = E_{mn}\psi_{mn}##.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
