Alpha particle approaching a gold nucleus
8 replies · 3K views
Randell Julius
An alpha particle approaches at high speeds a gold nucleus with a charge of 79e. What is the electric force acting on the alpha particle when it is 2.0e-17 m from the gold nucleus?
FE=k(q1q2)/d2
FE=k(q1q2)/d2
FE=9e9((2e)(79e))/(2.0e-17)2
FE=9.1e7 N
The answer in the back of the book says that it is 9.1 e -12 N.
Not sure where I went wrong.
on Phys.org
TSny said:
If you want the force to be in units of Newtons, what should be the units for electric charge?
It should be in Coulombs.
Yes. It looks like you made a minor error in expressing the two charges in terms of Coulombs. Check to see if you missed a factor of 10-19.
The value we used for e was 1.602e-19 Coulombs
Yes. Note that e occurs twice, once for each charge. So, how many factors of 1.602 x 10-19 occur in the numerator of the force calculation?
2 factors of 1.602 * 10-19.
OK. My mistake. Since your answer was off by exactly a factor of 10-19, I assumed (wrongly) that you had missed a factor of 10-19 in substituting for the charges. Now that I have grabbed my calculator and checked your work, I'm getting the same answer as you. The distance for d given in the problem looks way too small to be reasonable. (It is much less than the size of a nucleus!) So, I think there must have been a misprint in the problem statement for the distance d.
Okay thank you very much.
