Alright PF logged me out and erased all my work
  • Thread starter Thread starter flyingpig
    Work
The discussion revolves around a physics problem involving two parallel wires attracting each other with a specified force per unit length. The user initially struggles to find the location where the total magnetic field is zero, mistakenly calculating the position as 0.25 m instead of the correct 0.333 m. Clarifications are made regarding the forces acting between the wires and the need to determine the current in the lower wire. The conversation emphasizes the relationship between the currents and the magnetic fields produced by each wire, ultimately guiding the user to the correct solution. The thread highlights the importance of accurately setting up equations to solve magnetic field problems in electromagnetism.
flyingpig
Alright I spent like 20 mins typing out the problem and PF logged me out and I couldn't hit backspace to save work when I hit submit thread so I apologize if this seemed a lack of effort...
Problem
Two long, parallel wires are attracted to each other by a force per unit length of 320 μN/m when they are separated by a vertical distance of 0.500m. The current in the upper wire is 20.0 A to the right. Determine the location of the line in the place of the two wires along which the total magnetic field is zero.
http://img140.imageshack.us/img140/7098/bfield.th.png
Uploaded with ImageShack.us
So I did
|F_{12}| = |-F_{21}|
\frac{F_{12}}{l} = \frac{F_{21}}{l}
I_2 B_1 = I_1 B_2
I_2 \frac{\mu_0 I_1}{2\pi (0.5 - y)} = I_1 \frac{\mu_0 I_2}{2\pi y}
Solving I get
0.5 - y = y
y = 0.25 which is wrong. The actual answer is 0.333m
Infuriating !!! Isn't it?
Give me a minute, I'll solve this.
EDIT: Before I do anything. Are you sure that your expression here is correct?:
<br /> I_2 B_1 = I_1 B_2<br />
When I expand from:
<br /> |F_{12}| = |-F_{21}|<br />
I get:
<br /> I_1 l_1 B_1 = I_2 l_2 B_2<br />
Where the lengths of the wires can cancel since they are the same variable.
So the resulting equation where you can sub your mu-sub-zero/2pi, etc. would be:
<br /> I_1 B_1 = I_2 B_2<br />
Let me know if this makes sense.
What is meant by F12 & F21.
Be more explicit than usual.
The force exerted by 1 onto 2 is supposed to be F12, same with F21
Of course we know that these forces are equal (in magnitude), and opposite. ---Issac Newton tells us that, even though he knew nothing of these equations relating current and B field.
What the problem wants from you is to:
Determine the location of the line along which the total magnetic field due to the two wires is zero.​
Yes, I did change the wording so the problem makes sense. If the problem is different, in a significant way, than what I said, please change it to the wording of your textbook.
I know that's why I set the force per unit length equal
There are two main steps needed to solve this.
First, you need to find the current in the lower wire. This is similar to a problem you've already done. Here you know the force per unit length & its direction, the distance between wires and the current in one of the wires.
Previously, you were given both currents & the separation -- and were asked for the force per unit length.
The second part is to find the location where the B field due to the two wires cancels (is zero).
OKay so I1 is
\frac{F_{12} 2\pi y}{l\mu_0 I_2} = I_1
So numerically it is
Please...need more help
\frac{F_{12}}{\ell}=320\,{\mu}\text{N/m}
y=0.500\,\text{m}
I_2=20.0\,\text{A}
Calculate I1.
I1 = 40a
In what direction is I1, if the wires are attracted to each other?
Same direction as I2 as I have drawn in the picture.
Yes, you did draw it in your picture. It's helpful to make your answer as complete as is reasonably possible.
Now, for the main question: (Remember, here you are only concerned with B field, NOT force.)
Notice that the magnetic field due to wire 1 is out of the page (positive, in my view) anywhere above wire 1 (y > 0.500 m) & the magnetic field due to wire 1 is into the page (negative, in my view) anywhere below wire 1 (y < 0.500 m) .
Similarly, the magnetic due to wire 2 is positive for y > 0, & negative for y < 0.
So, the only place where adding them together can cancel them, is: ______ ?
y ∈ (0,0.5)
OK, solve the problem.
Yup I got y = 1/3. I was close though...I mean I had the idea of setting something equal to something.
Thanks again Sammy lol.
