What is the next step for determining convergence or divergence of this series?
whatlifeforme
determine either absolute convergence, conditional convergence, or divergence for the series.
\displaystyle \sum^{∞}_{n=1} (-1)^n \frac{6n^8 + 3}{3n^5 + 3}
I cannot use the alternating series test since the function is increasing not decreasing.What should i do next?
Since the sequence (apart from the (-1)n factor) is increasing, doesn't that give you a hint as to what the series is doing? It might help to write a few terms in the series.
can i use the divergence test?
Yep, it diverges since its terms do not approach zero.
thanks.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
