Alternative proof to a trivial problem
  • Level: Undergrad
  • Thread starter trees and plants
    Proof
43 replies · 5K views · last reply
universe function said:
I think if A⊆An then An⊆∪n∈ℕAn. I do not know what to do next.I tried somehow.
That can't be right. We already know that every ##A_n## is a subset of ##A##. What you need to do is to show that every element of ##A## is in at least one of the ##A_n##.
Note that ##A## is open and, therefore, every ##x \in A## has a neighbourhood in ##A##. That's the defining property of an open set. That geometrically is very close to what you need to show. If we take ##x \in A## then for some ##n## we have ##x \in A_n##.
You need to complete the proof rigorously, but do you see the idea?
I thought of something, but I suppose it is wrong. I will say it: A is open, so we have B(x,r)⊆A and for y∈B(x,r) also y∈A. d(x,y)<r, so d(x,y)=r/2 and because d(x,Ac )>1 we choose a y for d(y,Ac)=1+1/2 and we take as r=10/2,so d(x,Ac)≥d(x,y)-d(Ac,y)=r/2-3/2=10/4-3/2=1.
I thought of something, but I suppose it is wrong. I will say it: A is open, so we have B(x,r)⊆A and for z∈B(x,r) also z∈A. d(x,y)<r, so d(x,y)=r/2 and because d(x,Ac )>1 we choose a y for d(y,Ac)=1+1/2 and we take as r=10/2,so d(x,Ac)≥d(x,y)-d(Ac,y)=r/2-3/2=10/4-3/2=1.
I can't follow any of that. You must get into the habit of specifying what things are and using the quantifiers ##\forall## and ##\exists##. What are ##x, y, z, r##? And why is ##d(x, A^c) > 1##?
To give you a bit more help, you could start with:
Let ##x \in A##. As ##A## is open, there exists a neighbourhood of ##x## within ##A##. I.e. ##\exists r: B(x, r) \subseteq A##.
If we took the union of B(x,rx) and the union of An?Would it help?Because a set is open if it can be represented as a union of spherical neighborhoods.
Which ##n##? To do what? You're trying to find ##n## where ##x \in A_n##.
Hint: ##n## must be related to ##r## somehow.
If we consider r=1/n and y∈Ac?What is the solution?I do not know.
That's getting close. Technically, you let ##n > 1/r##. Then you show that ##\forall y \in A^c##, we have ##d(x, y) > 1/n##.
That tells you that ##d(x, A^c) \ge \frac 1 n > \frac 1 {n+1}## and you're done.
You have to put that all together though.
I reached so far at least.It is just the details I had to deal with, although they are important and they are needed.Thank you.I must leave from the forum now.I will see you tomorrow hopefully.
I always thought that ##d(x,y)\ge 0## was part of the definition?
So did I, but apparently this condition can be deduced from the others.
There seems to be a long series of posts which appear to lead to this conclusion. Could you summarize it, starting from the beginning?
From post #3 or #4 we switched to a new problem.
If I understand you correctly, you never proved ##d(x,y)\ge 0## can be deduced, as opposed to being part of the definition.
Not on this thread. It's on the wikipedia page if you are interested.
